Stock Air Filter Replacement
Old Apr 15, 2009 | 02:59 PM
SSRCHRIS's Avatar
I have searched for this info but no luck. I need to change out my wifes air filter on her 06 SS/SC. It appears to sit in the fender well. Any quick tips or tricks on accessing it?
Thanks!
Old Apr 15, 2009 | 05:35 PM
DaBuzzard's Avatar
Guessing no owners manual?
Pop off 3 snaps (kinda c shaped, hinged at lower end), top with the flex hose comes off, panel type filter inside. At least thats how the 2.4's are, can't see the 2.0 being a lot different....other than being on the other side of the car
Old Apr 15, 2009 | 06:19 PM
Coblasts's Avatar
Super charged cobalt requires you to access the filter through the fender liner.
You should be able to do it with the wheel on but might be easier if you have it off.
On the driver side the front portion of the fender liner can be unscrewed and pulled down to give you access to the air filter.
Its pretty straight forward from there but if you dont have enough room remove the wheel and fender liner and you then will have lots of space.
Old Apr 15, 2009 | 06:41 PM
CobaltNCamaro's Avatar
I just did this job today (clean out filter) and for the 2.0 S/C I would definitely take the wheel off. Next remove the 6 or 8 small bolts from the fender lining and bottom of front bumper and there you go. much easier access!
Old Apr 15, 2009 | 06:42 PM
D4u2s0t's Avatar
not even close
Best bet is follow the instructions the other guy posted, and take off the wheel. It's a bitch with the wheel on.
Old Apr 15, 2009 | 07:15 PM
DaBuzzard's Avatar
Damn, that seems to be a wee bit convoluted for an air filter. Guess the blower takes up way more room than I thought!
Crap, got it wrong twice this month and it's only half over
Old Apr 15, 2009 | 08:30 PM
rukkee's Avatar
I can actually do i quite easy with the wheel on now , just pull the inner fender down and yank the filter out .
If you need to just clean the maf or have a CAI...pull the headlight out and it's easy to get to. I've gotten a cai filter out threw there.
Old Apr 16, 2009 | 06:33 AM
SSRCHRIS's Avatar
The manual does not give instruction for the changing of the filter. Thanks to all for the info. I will take care of it this weekend.
Old May 11, 2009 | 03:33 PM
SSRCHRIS's Avatar
Could not agree more. It is very easy to change the filter with the wheel on. Thanks to everyone for the tips!
Old May 11, 2009 | 04:44 PM
red06SC's Avatar
and located inside the fender
and being housed in an airbox
and being a cylinder type that requires airbox removal and disassembly to access
Old May 11, 2009 | 04:56 PM
DaBuzzard's Avatar
Message already received.....4 weeks ago. But thanks anyway
Sean Cummings
Oct 31, 2015 06:32 PM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
vjoel2011
Oct 2, 2015 12:11 PM
camaromanss1992
Oct 1, 2015 10:51 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
