Stuck Driver's Side Rear Caliper (No eBrake)
Old Aug 2, 2012 | 09:11 PM
boostbalt's Avatar
I have a 2006 LSJ, noticed that the ebrake stopped working, you can pull it all the way up and the car can still be moved. Not good.
Anyway, since we have a self-adjusting ebrake in the SC, I assumed this was due to a stuck caliper. I took the car for a short drive, sure enough, driver's side rotor hot as hell, passenger side, not bad.
Now, I've done the rear brakes before, just wondering, are there any special considerations I need to make? I believe this caliper got stuck very recent as the ebrake has been working up until the last few days.
I am going to jack up the car, take off the tire, remove the caliper and grease the pins. The caliper only has 67K Kilometers on it, I assume it just needs to be greased up, it looked awesome when I did a brake job just 5 months ago.
Any advice is appreciated.
Old Aug 2, 2012 | 10:02 PM
Powell Race Parts's Avatar
check the e brake trunnion under the rear cupholder
Old Aug 3, 2012 | 10:33 PM
Coblasts's Avatar
Canadian winters will do that to the calipers,
Old Aug 3, 2012 | 10:40 PM
marcwo's Avatar
This is an occasional issue with cobalts, might have to replace the caliper.
Old Aug 4, 2012 | 12:58 PM
boostbalt's Avatar
Thanks, is there a chance it's stuck because of the trunion itself?
Old Aug 4, 2012 | 02:15 PM
^^^ no. if its really stuck the caliper is screwed, if one side is not working, the trunnion may be an issue.
Old Aug 4, 2012 | 02:39 PM
boostbalt's Avatar
Well it's worth checking the trunnion then first to see if it's causing an issue! Thanks I will do this.
I assume, if it is causing an issue, I'd want to loosen it off, drive the car a short distance, then tighten it back up?
Cheers
Old Aug 13, 2012 | 06:41 PM
boostbalt's Avatar
FYI, calipers needed to be replaced, did both sides and had the fluid flushed at the same time. I'd recommend doing this if your ebrake stops working too.
Old Aug 14, 2012 | 12:12 PM
insylem's Avatar
Similar situatio happened to me at about the same milage on my 06 SC. Except it was the passanger side. That side wasnt releaseing. Just like you discribe, but I dont remember it ever being hot because I never checked that. But anways, Yes you should replace that caliper. It's not that difficult. Also, like the OP said, check under the brake handle and cup holder. Chances are oneof the cables came off of the balancer clip. That happened to me as well makeing the handle not tight to pull.
Old Aug 14, 2012 | 12:13 PM
insylem's Avatar
Yes, what happened to me,
My caliper got stuck,
So when I let the brake handle down,
The cable came loose and disconected.
Old Aug 15, 2012 | 01:47 PM
boostbalt's Avatar
The resolution to your eBrake going loose is to replace the rear calipers, nuff said.
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
