Stumbling on Acceleration
Old Dec 19, 2011 | 10:58 PM
fanbelt.1's Avatar
My 2006 Supercharged SS stumbles on part throttle &full throttle acceleration. Not quite a full-blown misfire, but close. Dealer says diagnostic tests reveal no problems, but the motor feels like crap now when accelerating.He says to stop using premium fuel and switch to regular, as I now have caused carbon deposits. Sounds fishy to me.
Has anyone else come across this problem of engine stumbling?
Old Dec 20, 2011 | 02:25 AM
BlkWdoSS's Avatar
WTF! 93 causes carbon build up? get away from that dealership now. need more info of mods and when its doing it, but your problem can be solved here
l8r,
PD
Old Dec 20, 2011 | 02:50 AM
RooTBeeR's Avatar
this could be a lot of things, need more info...
dirty maf, clogged air filter, bad plugs, o2 sensors, clogged cat...list goes on
Old Dec 23, 2011 | 11:23 AM
MyOtherSS's Avatar
Try cleaning the throttle body.
Old Dec 23, 2011 | 11:24 AM
05Slowline's Avatar
dirty maf, clogged air filter, bad plugs, clogged cat...list goes on
those
whatever u do dont stop using 93 octane
my car feels stumbly too sometimes, does it happen when ur in really low rpms like 1-2k
Old Dec 23, 2011 | 11:27 AM
SylverSS/SC's Avatar
my car does this in the higher rpm in 4th and 5th. I have to do some maintenance on it. Clean maf, TB, change plugs, Possibly seafoam, Change filter. Chances are one or a combination oif these are the culprit!
Old Dec 27, 2011 | 09:01 PM
Shrydo's Avatar
I have the same model, doing the same thing, no CEL, no mods, TB clean, cat is good, spark plugs are good, had a mechanic take a quick look, hes stumped too.
Old Dec 29, 2011 | 05:05 PM
fanbelt.1's Avatar
The car has zero mods....completely stock. 25k easy miles. Car never raced or abused (apart from not being garaged). Services performed were "Recarbonization Engine SBC", "Fuel Induction Kit" (throttle body cleaning I believe), and replaced Mass Airflow Sensor. However, dealer documentation records that a) they couldn't duplicate the problem (I believe it's impossible NOT to duplicate it), and b) they could not identify any problems after tunning diagnostic checks.
When we returned several weeks later reporting no improvement, we were told that we were using g "cheap" fuel (I.e., Costco), and that we should stick to a reputable filling station and stay with it. After several weeks we returned reporting no improvement, and were then told that the 93 Octane fuel we'd used since Day 1 too high, leading to carbon deposits, and that we should switch to "regular" fuel.
Old Dec 29, 2011 | 05:18 PM
1AJeremyD's Avatar
Ya don't listen to them about NOT using 93 octane. The car is a Force induction engine and using a lower octane will cause Knock. Best bet would be to change out the plugs with the proper gap and see how that does. My car had a little hesitation but once I took the old plugs out (gapped at .060mm) and gave them the proper gapping it has gone away.
Old Dec 29, 2011 | 06:30 PM
winning_blue's Avatar
if you have a CAI, clean it/recharge it. worked for me..
Old Jan 7, 2012 | 09:45 AM
Sully20's Avatar
Yep. I'm still getting a minor Hesitiation in the 1,000-2,000 RPM range, Not half as Bad as when I had my exhaust Leak, But its still there. I did buy some new NGK's about 1-2 months ago and never Gapped them, So with my MOD's what would one recommend? Thanks
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
tomj77
Oct 4, 2015 11:39 AM
ThoR294
Sep 28, 2015 05:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
