Stupid GM Policies
Old Nov 3, 2011 | 10:31 PM
bluebalt07's Avatar
Stupid GM Policies
so i've been having an oil leak around my timing chain tensioner for a while now and just took it to the dealership this week because i found out the car is still under the power train warranty. Monday it goes in and they replace the tensioner and valve cover gasket and give it back. Next day its leaking worse than before so back it went today. They called and said they found something wrong with the head but instead of just replacing the head they said they are going to fix it with epoxy. They said that is the gm policy. Anyone else think that its an awful idea to repair such a vital engine part with glue?
Old Nov 4, 2011 | 12:00 AM
CanadianCobalt's Avatar
Thats bogus, call GM.
Joel
Old Nov 4, 2011 | 10:35 AM
bluebalt07's Avatar
They said it will have a separate warranty for 1 year/ 12k miles but I just think its stupid because I don't see that holding up well
Old Nov 4, 2011 | 10:39 AM
gm does anything in their power to not help their crustomers. epoxys a bad ideal
Old Nov 4, 2011 | 11:07 AM
Chevrolet Cust Svc's Avatar
Can I follow up with your dealership for you? Please contact me via pm with your name, VIN, and name of your involved dealership.
Looking forward to helping,
Sarah
GM Customer Service
Old Nov 4, 2011 | 11:10 AM
07SSYellow's Avatar
Resident Post Whore/Troll
haha good ole GM Cust Care popping in
Old Nov 4, 2011 | 11:16 AM
1AJeremyD's Avatar
Ya I wouldn't let just epoxying the head fly. No way would that hold up for the life of the vehicle. Definitely demand a new head before the warranty runs out!
I'm actually happy to see that there is a GM rep on here for the most part. I know for my explorer forum I am on there's a ford rep that helps out a bit
Old Nov 4, 2011 | 12:39 PM
bluebalt07's Avatar
I sent the GM rep a pm so we'll see where it goes from here
Old Nov 4, 2011 | 12:48 PM
insylem's Avatar
To me? Sounds like they are trying to temp fix it until the warranty runs out
Old Nov 4, 2011 | 01:23 PM
bluebalt07's Avatar
Idk what they are trying to do but I couldn't believe it when they told me that
Old Nov 4, 2011 | 01:25 PM
JacBlackSS/TC's Avatar
wouldn't be the 1st time i went through this with a dealer they basically pieced my car back together and now that its having issues again they don't wanna fix oh well
Old Nov 4, 2011 | 01:39 PM
cranemaster's Avatar
Subed to this thread, my car has oil all over the bottom of the car, has since new. Never a drip on the ground. Finally going to take it in...
Will be fun! They always try to bs me!
Old Nov 4, 2011 | 02:11 PM
bluebalt07's Avatar
Mines had a leak for quite some time too and it was always all over the side of the block with the exhaust mani and also dropped down onto the axle and control arm. Finally found the source to be the timing chain tensioner so I'd check that if I were you. It's directly to the left of exhaust mani when looking from the front of the car and it looks like a big ass bolt head. It also pools up on top of the water pump hump after you shut the car off
Old Nov 4, 2011 | 02:29 PM
Staged07SS's Avatar
Administrator
Administrator
I found a hairline crack on my cyclinder head 1 month after I purchased my car back in 07'.... (casting imperfection)
The dealer tried saying they will just repair the crack. I told them absolutely not, I want the head replaced.... Sure enough (w/o much fighting) they replaced the head after I showed them how the oil seeped out of the crack.
Fight it man.... Get it fixed right!
Old Nov 4, 2011 | 02:52 PM
bluebalt07's Avatar
Ohh there's definitely no way I'm gonna settle for a patch job. I'll see what the GM service rep that posted in this thread comes up with and go from there. If I have to fight with the dealer about it I will
Old Nov 4, 2011 | 03:52 PM
bluebalt07's Avatar
So I just got a pm back from Sarah the gm rep. Long story short she said when she spoke to the dealership that the tech noticed some performance modifications that could interfere with the warranty. My mods are in my sig and i know there is no way that anything of them could've possibly put a crack in the head
Old Nov 5, 2011 | 12:19 AM
08baltls's Avatar
They have to be able to prove beyond doubt that a modification you did caused the issue. If they cant, and from looking at your mods they cant, then its actually illegal for them to not fix the problem. Just swapping a header isn't enough to crack a head so they cant technically void the warranty on that part. Now if you jave exhaust problems they can but not with the head or block unless you mdified them internally.
Old Nov 5, 2011 | 12:23 AM
bluebalt07's Avatar
Yeah I think congress actually passed a law about this sorta thing. I'm gonna try to talk to someone from GM before it goes in Tuesday because IMO it's almost pointless to take it in for their stupid repair when I'd rather them swap it out completely
Old Nov 5, 2011 | 02:11 AM
06SS ALL DAY's Avatar
i would let them fix it with epoxy, then beat the living **** out of it and pop the motor then get a new one. so stfu and do that. then be happy later
Old Nov 5, 2011 | 09:57 AM
insylem's Avatar
Even if your mods cause a problem. I know with K&N They will pay for your car to get fixed, if their mod causes a problem. Almost had to have them do that to mine, since my K&N was rubbing on my brake lines, but I managed to catch it in time. They gave me a full refund for my K&N after I sent the pictures of where it was rubbing on the brake lines and the PCM.
Old Nov 5, 2011 | 10:06 AM
BlueStang's Avatar
I always find it amusing when someone mods their car to perform above factory specs then expects GM to fix it for free when something breaks on it
Old Nov 5, 2011 | 10:24 AM
Who Gee's Avatar
^ x2
Old Nov 5, 2011 | 12:39 PM
bluebalt07's Avatar
The mods on my car are only made to "free" up more power. All they do is improve the flow of air into and out of the engine. If anything they put less strain on the engine and should help prolong its life. There's absolutely no way that simple bolt ons put a crack in the head
Old Nov 6, 2011 | 06:45 AM
BlueStang's Avatar
Check your warrenty terms in the owners manual, if I remember when reading mine for the Cobalts I had it states altering the origional build of the car could and would void your warrenty.
Old Nov 6, 2011 | 09:12 AM
bluebalt07's Avatar
If it does say anything about this, GM is breaking the law.
https://www.cobaltss.net/forums/prob...y-laws-157346/
