Stupid Question...Where is my MAF Sensor
Old Dec 26, 2009 | 01:02 PM
gpro's Avatar
I have an '05 SS/SC, and I almost constantly have code P0171. I wanted to try cleaning the MAf sensor just to see if that would help, but I cant find the damn thing.
I feel like such an idiot. I've seen it on my other car, I thought I'd be done already spraying this thing, but I have no idea where it is. If someone could find me a picture, or point me in the right direction, I would greatly appreciate it.
Thanks.
Old Dec 26, 2009 | 01:06 PM
D4u2s0t's Avatar
it's on the intake tubing under the driver side front fenderliner... easiest way to get to it is to take off the wheel, and take off some of the clips of the fenderliner. If you have small hands, (and patience) you may be able to get it through the headlight. But if you drop a screw, you may have to take off the fenderliner to get to it anyways, so I would save the potential extra step and just do it that way.
Old Dec 26, 2009 | 01:13 PM
joblaney's Avatar
go see this video http://www.youtube.com/watch?v=PDLMsYpAI7o
near the end they show the MAF
Old Dec 26, 2009 | 01:29 PM
gpro's Avatar
thanks guys
Old Dec 26, 2009 | 01:49 PM
Nortybignort's Avatar
I thought this code was from a cold air intake?I get it once in a while in the winter when its cold.I have an injen intake.
Old Dec 26, 2009 | 02:37 PM
rukkee's Avatar
GM had an updated calibration for the p0171 issue years ago . Has you car ever been updated ?
Service Information
Home Publications Number Search New Bulletins Bulletin Search Feedback Help
2006 Chevrolet Cobalt | Cobalt, Pursuit (VIN A) Service Manual | Document ID: 1842831
#06-06-04-033: 2.0L/2.2L LSJ/L61 Engine Malfunction Indicator Lamp (MIL)/Service Engine Soon (SES) Lamp Illuminated with DTC P0171, Fuel Trim System Lean, Set (Reprogram ECM) - (Jun 21, 2006)
Subject: L61 Engine Malfunction Indicator Lamp (MIL)/Service Engine Soon (SES) Lamp Illuminated with DTC P0171 "Fuel Trim System Lean" Set (Reprogram ECM)
Models: 2005-2006 Chevrolet Cobalt, Cobalt SS Supercharged
2006 Chevrolet HHR
2004-2006 Chevrolet Malibu
2005-2006 Pontiac Pursuit (Canada Only)
2004-2005 Saturn ION Redline
2005-2006 Saturn ION
with Ecotec™ 2.0L or 2.2L I-4 Engine (VINs P, F - RPOs LSJ, L61)
Condition
Some customer may comment that the MIL/SES lamp is Illuminated. Further diagnostic investigation with a scan tool may reveal a DTC P0171 Fuel Trim System Lean. No other driveability or performance concerns may be reported.
Cause
The most likely cause of this issue may be that the engine calibrations need to be updated to correct a variation in the Mass Air Flow Sensor.
Correction
DO NOT replace the MAF sensor, the ECM or any other parts.
Important:
• Chevrolet/Pontiac Dealers: The ECM calibration is available to dealerships as part of TIS2000 incremental satellite update version 6.5, which was broadcast to dealers June 12, 2006 or later. For the dealerships that use CDs, they were mailed out June 2006 or later.
• Saturn Retailers: Before installing the new ECM calibration, make sure the Saturn Service Stall (SSS) version is TIS 6.5 2006 or later.
• While the ignition is OFF, apply the parking brake to disable the daytime running lights (DRLs) prior to starting reprogramming procedures
• The technician must select the "Reprogram" option in order to reprogram the ECM.
Reprogram the ECM with the latest calibration. This calibration, or any that follow, is designed to address this DTC P0171 concern. Refer to Service Programming System (SPS) in SI for reprogramming procedures. As always, make sure your Tech 2Ž is updated with the latest software version
Warranty Information
For vehicles repaired under the 8-year/80,000 mile (130,000 km) emission controller warranty, use:
Labor Operation
Description
Labor Time
J6353
Reprogram ECM with SPS
0.4 hr*
* U.S. Saturn Retailers: Refer to Saturn Electronic Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
Š 2009 General Motors. All rights reserved.
Old Dec 26, 2009 | 04:44 PM
Coblasts's Avatar
If you have one,Check the cai for holes rubbed through it.
Old Dec 26, 2009 | 07:52 PM
SSchargedSS's Avatar
oiled filters give cels. Injen filters are oiled. They give cels at the most random time. I switched to dry flow filter on my injen and havent had a cel in over two years.
Old Feb 17, 2016 | 12:24 PM
Blackcobalt07's Avatar
Ok coablt
Would this be the same for an 07? I'm haveing trouble finding mine?
Old Feb 23, 2016 | 01:05 AM
ItalianJoe1's Avatar
Yes, same for all supercharged cobalts.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
tomj77
Oct 4, 2015 11:39 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
jmelton327
Sep 26, 2015 10:04 PM
