Supercharger oil fill amount?
Ive read many conflicting ideas as to how much oil to put in your supercharger.
Eaton apparently says 3.4 oz and zzp say 6oz.
Ive also saw pictures where oil has been changed and 3oz came out.
Does anyone actually know!?
*Reason I cant check mine is the snout seal was bad and had no oil.
It's 3.4 oz for the M62. I spoke to Eaton about this two years ago when I changed the oil in my supercharger.
ZZP is incorrect.
Only 3 oz came out of some, because unless you do a complete rebuild, you wont get every last drop out all of the time.
Also, some may have leaked a bit out due to a leaky snout shaft seal.
ZZP is incorrect.
Delta coupe
09-30-2015 08:11 AM
z28addiction
09-28-2015 12:03 AM
