t/c problem and cam sensor problem
alright I have a 2006 cobalt ss 2.4L auto 60K miles.
1.)the traction control is being a huge pain in the ass. the t/c will randomly turn off while in drive, and all shifts are insanley hard, like the car is being shoved. I've done some research, and what i've come up with is that the EBTCM is bad, or that the traction control module is bad. anyone have this problem?
2.) I recently threw a code that the cam sensor was bad. no biggie $40 and its fixed. 2 days later, it throws the same code..... and the next day the engine light does not come on. it will do this once or twice a week. i got fed up and went to a local place and had them check it out, same think. cam sensor bank 1. and i had it replaced by them. and today, the engine light came back on....
. probably for the cam sensor.
also both of these problems tend to happen at the same time or one will occur then the other will follow shortly after.
Any help would be nice
. probably for the cam sensor.also both of these problems tend to happen at the same time or one will occur then the other will follow shortly after.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
