Is there a common failure point on O2 wiring harness
Old Aug 1, 2020 | 03:57 PM
Blasirl's Avatar
I wanted to know if there was a common failure point on the wiring harness for what I think is the rear O2 sensor? Is there a somewhat simple fix if there is a common one. It looks like the three DTC's all point toward the wiring so I figure I would start there. Thanks for any help.
My daughters 2007 Chevrolet Cobalt LT with the 2.2 L 4-cylinder engine (Current mileage: 93153) has the following DTC's:
From my Actron PocketScan Plus CP9550 scanner
P0036 (CNF) O2 Sensor Heater Control Bank 1
P0036 (PND) O2 Sensor Heater Control Bank 1
P0054 (CNF) Heated O2 Sensor Heater Resistance Bank 1 Sensor 2
P0054 (PND) Heated O2 Sensor Heater Resistance Bank 1 Sensor 2
P0141 (CNF) O2 Sensor Heater Circuit Bank Sensor 2
P0141 (PND) O2 Sensor Heater Circuit Bank Sensor 2
and from my
Vgate Maxi-Scan ECU-Provs890 scanner set to Chevrolet
$07EA
$07E8
I looked up online and found these explainations:
Potential causes of a P0036 trouble code may include:
Open circuit inside oxygen sensor or open power or ground wires to oxygen sensor
Exhaust system ground strap may have become corroded or broken
PCM/ECM or oxygen sensor heater circuit wiring has failed
Read more at: https://www.obd-codes.com/p0036
Potential causes of a P0054 trouble code may include:
Burnt, broken, or disconnected wiring and/or connectors
A faulty O2 sensor
Blown fuse or burnt fusible link
Defective engine control relay
Read more at: https://www.obd-codes.com/p0054
A code P0141 may mean that one or more of the following has happened:
An open or short to ground in the wiring harness
O2 heater circuit wiring high resistance
O2 heater element resistance is high
Internal short or open in the heater element
Note: Typically a failed catalytic converter does not cause this code. You're more likely to see a P0420 code for a failed converter.
Read more at: https://www.obd-codes.com/p0141
Old Aug 2, 2020 | 03:52 PM
LsCobalt07's Avatar
Make sure the wires are secured, I've had the wire for the rear O2 sensor come loose and drag. The wires eventually shorted and blew the underhood EXH / emissions fuse, giving me a bunch of codes related to both the O2 sensors and the MAF sensor. Inspect all the O2 sensor connectors and wiring harnesses for fraying, abrasion or signs of melting.
Old Aug 7, 2020 | 08:11 PM
Blasirl's Avatar
Just a followup. I had to have the sensor replaced . He said it was so difficult to get out that the threads needed to be chased to get the new one in. Cost me $130 with the sensor being a GM part.
Chris06CobaltSS
Apr 14, 2016 12:00 PM
nolimits
Jun 29, 2012 07:07 PM
TY8425
Apr 26, 2012 06:59 PM
JustinMT15
Sep 7, 2010 04:17 PM
Sh0nuff
Sep 20, 2009 12:17 PM
