Third Brake Leak
Old Mar 20, 2015 | 01:03 PM
Raptorunbound's Avatar
Third Brake Leak
Hey guys, I recently replaced my third brake light and found that it leaks slightly. I would like to fix the problem before it gets bad. I am just curious if anyone knows where I can get some of the weatherstripping to go around it? Only half of it leaks and that is the same side that has a crappy seal with the weatherstrip.
Old Mar 20, 2015 | 01:16 PM
DFZ24's Avatar
Ok you need to describe or write it better or pictures lol
Because I dont understand how light is leaking, water operated lights? Lol
On the other hand you should just hand tight the screws enough that water should not go in.
Old Mar 20, 2015 | 01:36 PM
Sorry, it leaks water when it rains. It not a matter of just tightening it because it only leaks on one side of the light. That side is missing some of the weatherproof strip that was there from the factory. I am trying to find a new weatherproof strip
Old Mar 21, 2015 | 11:46 PM
DFZ24's Avatar
Should be able to find any weatherstrip in the autoparts or use silicone to cover it.
Old Mar 23, 2015 | 07:04 AM
tomj77's Avatar
Take it off and silicon it. Will probably be better than the weather striping anyway. Do u actually take the light off to get at the bulb? Cause u don't have to do that.
Old Mar 23, 2015 | 12:19 PM
Well, I put an entirely new light in. The new one didn't come with any weather protection and the old stuff is really bad and worn.
Old Mar 23, 2015 | 12:41 PM
tomj77's Avatar
If u can't find any, ask dealer or goto wrecker and get some from a wrecked balt
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
