Third Brake Leak
Third Brake Leak
Hey guys, I recently replaced my third brake light and found that it leaks slightly. I would like to fix the problem before it gets bad. I am just curious if anyone knows where I can get some of the weatherstripping to go around it? Only half of it leaks and that is the same side that has a crappy seal with the weatherstrip.
Because I dont understand how light is leaking, water operated lights? Lol
On the other hand you should just hand tight the screws enough that water should not go in.
Sorry, it leaks water when it rains. It not a matter of just tightening it because it only leaks on one side of the light. That side is missing some of the weatherproof strip that was there from the factory. I am trying to find a new weatherproof strip
Take it off and silicon it. Will probably be better than the weather striping anyway. Do u actually take the light off to get at the bulb? Cause u don't have to do that.
