Those of you that have a Hurst STS...
Old Apr 26, 2009 | 01:26 PM
BlackSSNick's Avatar
I installed mine last august, and I have yet to correct this problem with it, but the shifter moves back in fourth. If I put my hand on it I can turn the shifter to the left and then it stops and then it turns back.
Did anyone else have this problem? and if so how do you correct it?
Old Apr 26, 2009 | 01:40 PM
Whining-devil's Avatar
yes i had this problem, the black set screw that it comes with is ****. i went to the hardware store bought a better set screw, and i drilled a bit into the actual shifter so the screw could go in deeper, then i used lock tite and never had the problem again.
Old Apr 26, 2009 | 02:41 PM
383_Stroker's Avatar
a better set screw solves the issue... you dont even have to drill the shaft, really
Old Jun 22, 2009 | 02:26 AM
J 1 Avs's Avatar
what do you mean by a "better" set screw, what makes it better
Old Jun 22, 2009 | 08:40 AM
One you can crank down tight on without stripping it..lol
Old Jun 22, 2009 | 04:49 PM
Adirondack_Cobalt's Avatar
this is info i need... i installed mine and the play makes me nervous.
Old Jun 22, 2009 | 04:52 PM
nicksredline's Avatar
yeah everyone has the problems... its the cheap allen wrench type screw.. if u get a normal screw and use it you should have no problems... i personaly would drill a tad bit into the shifter so it does not move ever but thats just me... Good luck
Old Jun 23, 2009 | 01:24 AM
J 1 Avs's Avatar
thanks for the info guys..i wasnt sure by better if you meant like longer or wider etc...so same size just stronger
Old Aug 31, 2010 | 01:11 AM
CatchMeIFyouCAN's Avatar
ahh
yess!! an answer to my problems!! and has anyone had a broken **** linkage due to the hurst sts???
Old Aug 31, 2010 | 01:47 AM
crazy-eh666's Avatar
x2. This is exactly what I did and no more probs...
Old Aug 31, 2010 | 09:26 AM
JetBlackSS's Avatar
Has anyone found a shift knob alternative for this setup? Between the below freezing winters and the 90* plus summers that shift knob can get a little unbearable!
Old Sep 8, 2010 | 09:35 PM
i agree
Old Jan 3, 2011 | 10:29 PM
nfarrall's Avatar
Does anyone have a picture of this set screw? Thanks in advance.
Old Apr 25, 2011 | 06:37 PM
Conspiracy2Riot's Avatar
Interested to see if anyone has found a shift knob alternative yet... this knob is horrendous here in AZ (and it's only 95, got another 20 to go)! Best solution I've found is one of the guys on here uses a knit shift knob cover. https://www.cobaltss.net/forums/sout...-knobs-247109/
CinciSS07
Feb 25, 2007 10:41 PM
CinciSS07
Feb 25, 2007 01:40 PM
