tire wear
Old Feb 11, 2010 | 08:12 PM
bbbevans89's Avatar
tire wear
i recently checked my tires for wear because of all the snow we have been getting and the passenger side tire is bald on the inner part only and the drivers side is even with good thread how can i solve this problem or what could the problem be thanks.
Old Feb 11, 2010 | 08:15 PM
BlackJackSS's Avatar
get an alignment. your camber is off it sounds like
Old Feb 11, 2010 | 08:17 PM
ssyellow's Avatar
alignment?
beat me to it^^^. Most shops will check it for you for free then let you decide what to do.
Old Feb 11, 2010 | 08:21 PM
hatrickstu's Avatar
its definitely alignment. a faulty tire will not just wear like that. could be tow, camber, etc.
Old Feb 11, 2010 | 08:56 PM
bbbevans89's Avatar
ok thanks guys i also for got the mention its the pirelli pzero nero stocks
Old Feb 11, 2010 | 10:16 PM
tomst9's Avatar
more than likely its excessive negative camber. Could also be toe-out on that wheel..... get the alignment checked.
tom
Old Feb 11, 2010 | 10:24 PM
QuickShift's Avatar
Rub your fingers flat against the tire...If it slides along easy one way and kind of grabs going the other way than its "feather edge" wear which would mean your toe is out...
My guess is its your camber if its only the inside of the tire... Either way an allignment should get you fixed up...
Old Feb 12, 2010 | 12:19 AM
im thinking also mayb you hit a pot hole this winter. and bent a strut tower or control arm if you hit hard enough. which would cause a canber problem.
toe is gonna be more of a choppy tread across the tire.
bigdeertz
Nov 17, 2016 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
