Tranny leaking Fluid Please help
my 08 LS is leaking tranny fluid from the output shaft on the passengers side anyone else ever have this issue? or know what caused it? I've got 100k warranty so i will prob end up bringing it to the dealer. I noticed about a week ago it would grind into 4th after being in 5th for awhile. figured it was just my fluid. and then i found that this afternoon. any info would help. P.S I already know about the TSB 08-07-29-001d for the 4th gear Sleeve Hub assembley. Just need to check my serial number and see if i fall into this bulletin
Iceberg
Sep 29, 2015 12:33 PM
