E-Brake
Old Feb 7, 2010 | 11:10 AM
afterlife04's Avatar
E-Brake
My E-brake isn't holding my car, I've replaced the pads on both the front and rear still the same. Any ideas? if my e-brake line is gone is that covered under warranty?
Old Feb 7, 2010 | 11:56 AM
blitzed~beretta's Avatar
whats it feel like when you pull the ebrake? prolly a broken cable or needs adjustment. what year and how many kms? could be warranty. where are you?
Old Feb 7, 2010 | 12:04 PM
Collin's SS's Avatar
https://www.cobaltss.net/forums/how-guide-43/how-adjusting-emergency-parking-brake-05-09-cobalt-w-rear-disc-brakes-168592/
^^ Very easy fix. No need to go to dealer.
Old Feb 7, 2010 | 12:15 PM
It feels like the e-brake isn't grabbing the brake enough. It grabs a little bit but not too much...The car has 48000 Km's it's an 07'. The dealer did a semi annual inspection last month....so i'm not sure if it's the cable or if it just needs to be tightened.
Old Feb 8, 2010 | 08:44 AM
2.2balt's Avatar
Probably needs to be tightened. They're **** in our cars. Mind you I have drums in the back which is worse, but the rear discs can loosen up fairly easy too.
Side note: is there any way to adjust the handbrake on a car with drums so it doesn't hit the god damn arm rest? I've adjusted everything. Drums cant be adjusted anymore without staying on, and the bolt on the handbrake has been adjusted too. lol
Old Feb 8, 2010 | 01:14 PM
HIValicious's Avatar
My E-brake is higher than usual. I think my cable needs to be adjusted.
g5mike
Sep 24, 2007 09:27 PM
blackphoenix
Mar 3, 2007 08:03 PM
qcpursuit
Mar 20, 2006 08:20 AM
Shamrock
Nov 30, 2005 08:39 AM
