need e-brake help
need e-brake help
ok... my e-brake is crappin out on me again.. allready been to the dealer once for it.. they relplaced the back brakes and everything and the cr was fine.. but it's got the same problem again.. basically.. the e-brake lever has no resitant at all.. and the car rolls when it's pulled all the way up.. what the hell can i do to fix this problem from coming back? should i go with aftermarket brakes in the back?
are you using the e-brake for other purposes?
If you are maybe it's pulling it too hard that's ******* it up...
Like an old prostitute, it doesn't re-tighten after a while.. it just stays loose forever... gah what an image.
XStylus
Redline Goods
17
Sep 3, 2015 10:30 AM
