Tranny problem maybe?
Old Mar 20, 2009 | 02:05 PM
mkulrey13's Avatar
OK, Ive had my turbo kit on for over a year, as well as my stage 2 spec clutch and fidenza flywheel and never once had a problem. Lately, ive noticed on cold starts engaging first i hear a sound. It sort of sounds like 2 pieces of metal sliding against each other as if they were dry? does not happen on 1-2-3-4-5-r shifts just N-1 or moving the car the first time. After a few mins if i come to a stop and start again the sound is gone. Would anyone know what this could be? I have not experience any shifting problems and it still drives/shifts the same as before.
Old Mar 20, 2009 | 02:43 PM
phillips01's Avatar
check your trans oil level and condition <dirty ect>/had a few that leaked low due to bad axel seal/ and caused weird noises.?
Old Mar 21, 2009 | 11:52 AM
mkulrey13's Avatar
Ill plan on replacing it soon. Any other suggestions?
Old Mar 21, 2009 | 01:00 PM
Tomtwtwtw's Avatar
Replace the fluid first...only other thing I could think of is a worn synchro? But if it goes away after you've been driving, it certainly sounds like a dirty / low fluid issue.
Old Mar 27, 2009 | 04:21 PM
mkulrey13's Avatar
Well i replaced my fluid, the noise is still there. Its only on cold starts when i first get rolling. After that its gone and is fine on warm starts and going. Again is sounds like 2 metal plates against eachother.
Old Mar 27, 2009 | 04:35 PM
Dainslaif's Avatar
Brake rotors/pads. If it goes away once warmed up I wouldn't be too worried.
Old Mar 30, 2009 | 02:00 PM
mkulrey13's Avatar
Its when im shifting...in the middle of letting my clutch out.
Old Mar 30, 2009 | 02:04 PM
joeworkstoohard's Avatar
mine started doing the same thing. 3 weeks later, i heard a bang and started dripping brake fluid from the inspection hole. right now, the cars on stands, half taken apart, i haven't gotten far enough yet to see what it is
OrangeCoba
Oct 1, 2015 10:00 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
