transmition problems...fml
Old Jan 30, 2011 | 07:16 AM
hellrose's Avatar
Angry transmition problems...fml
Sooo the cobalt ss I have is running however there is a grinding noise and when I do a uturn it doesn't want to accelerate when I press on the gas untill I straghten out the weels the rpms will go up but the car will just not accelerate ti I do so.it only does it when I am making the uturn. But the grinding noise is all the time. Doses this mean I have to replace the transmition or can I save it and just get it servised asap. If I were to replace the transmition how much am I looking at spending? I wanna know before I take it in and they tell me something when I could do it a less excpencive way trying to get me to spend as much as possible
Thank D
Old Jan 30, 2011 | 07:32 AM
cmatthewb101's Avatar
SC/TC/Or NA? Different trans. Mine makes a grinding sound on u-turns, but I'm pretty sure it's from tire rub Almost sounds like clutch slip. When you try to accel, the RPMs go up, but you don't accel? Correct?
Old Jan 30, 2011 | 08:19 AM
hellrose's Avatar
That's a really good question I have no clue how do I tell? And yea when I do a uturn it doesn't accelerate till I straghten out the weels. Its also not putting out as much power when accelerating say like from a red light it will shoot off but to go faster it will take a sec or two. I need all the info I can get seeing as of how every time I go into the repair shop since I a chick I get a lot more bs...I may not know much about this car but I'm not stupid either
Old Jan 30, 2011 | 09:15 AM
Armyguy151's Avatar
Where are you from? The slip sounds like a clutch..The S/C's clutches are garbage...if you put a stage 2 on your car you will need a clutch b.c it is going to slip not if, it will slip...if you need a clutch get a upgraded slave and throw out baring.
Old Jan 30, 2011 | 09:16 AM
Armyguy151's Avatar
I have a Exedy clutch and flywheel and haven't had a problem. I use to have a SPEC stage 3+ and I had a lot of problems out of it. As far as the grinding noise I will google and see what I can find about turning and making that noise.
Old Jan 30, 2011 | 11:47 AM
hellrose's Avatar
Unhappy
My cobalt ss is an automatic ...I need to see how much it will cosr me or if I even half to replace the transsmition
Old Jan 30, 2011 | 11:54 AM
05Slowline's Avatar
not really....plenty of people over 300 on stock clutch let alone 230hp stage 2 lol, need to lhtd
Old Jan 30, 2011 | 12:04 PM
Armyguy151's Avatar
well myself and a few other buddy's of mine went to stage 2 and had clutch problems...just saying
Old Jan 30, 2011 | 12:09 PM
rnjmur's Avatar
Automatic means it is a 2.4L SS/NA. If it grinds all the time that is not a good thing. It also sounds like you are getting clutch slip, but on an automatic that is more complicated than on a manual. You are going to have to take the car to a transmission shop and have them give you an estimate, it probably isn't going to be cheap.
Old Jan 30, 2011 | 12:15 PM
1BADSS/SC's Avatar
*transmission
lets say it together now:
"trans"-"mish"-"shun"
"transmission"
Old Jan 30, 2011 | 12:28 PM
LS6Rally's Avatar
probably gonna be about $1700-2,000.
Old Jan 30, 2011 | 12:32 PM
SilverSS_TNR's Avatar
Originally Posted by 1BADSS/SC
*transmission
"transmission"
i was waiting for this
Old Jan 30, 2011 | 12:45 PM
cobaltltblue's Avatar
Mine won't accelerate when I turn because the inside tire is trying to slip, and the traction control is kicking in! LOL
Old Jan 31, 2011 | 06:33 AM
hellrose's Avatar
Thumbs down
*transmission
"transmission"
ok now that u have settled that. Give me a freaken answer if not go spell check someone else that cares I need answers about the TRANSMITION spelled wrong just for u...I don't need to know how to spell it I don't give a flyong crap....as u were
That is all
Old Jan 31, 2011 | 06:36 AM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
*transmission
"transmission"
or if all else fails say TRANNY
let's try it
TRAN EEEEE
Like the one's at the gay bar :p
That is all
what is "flyong crap"
Last edited by tylerjclance; Jan 31, 2011 at 06:36 AM. Reason: Automerged Doublepost
Old Jan 31, 2011 | 06:37 AM
hellrose's Avatar
really is that just for parts! My 99 cogar was 4000 for its transmition to be rebuilt I was thinking it would cost me a lot more...ill take it in when they open and get it quoted thanks
R
Old Jan 31, 2011 | 07:33 AM
mongorat427's Avatar
Theres a ton of these on Ebay in the $400 to $600 range for the 2.4. Match up the year.
Old Jan 31, 2011 | 08:00 AM
Armyguy151's Avatar
I bought a used motor off of e-bay S/C for 1400.00 shipped and I haven't had a problem with it...GL
Old Jan 31, 2011 | 08:30 AM
alleycat58's Avatar
TR00F. OMG 30hp - RUN FOR THE HILLS OUR CLUTCHES ARE SLIPPING!
Sounds like a special down at Ho's City Wok.
Old Jan 31, 2011 | 10:42 AM
1BADSS/SC's Avatar
That is all
So u need answers about transmission being spelled wrong from me?
OK let me help you out again:
The spelling of transmission is the following. Say each letter aloud:
"T"-"R"-"A"-"N"-"S"-"M"-"I"-"S"-"S"-"I"-"O"-"N"
Ok lets try proper pronunciation again:
Trans = "Trans"
Mission = "Mish"-"Shun"
altogether now:
"Trans"-"Mish"-"Shun"
ColeJJones
How to Guide
30
Apr 2, 2011 04:31 AM
Ownedbyagirl?
Mar 29, 2011 11:32 PM
Ownedbyagirl?
Mar 29, 2011 03:13 AM
-Jayson-
Mar 16, 2007 02:39 PM
