Trouble Starting?
Old Oct 17, 2008 | 10:28 PM
XM15's Avatar
Question Trouble Starting?
For the past few months, every now and again my car has a little trouble starting. For the past week or two it has been happening every other day or so. I crank it for a few seconds and when it finally starts, it idles very rough and the tach bounces up and down, usually in a range lower than normal idle. If I shut it off and immediately turn it back on, it runs fine. Any suggestions as to what it might be?
Old Oct 18, 2008 | 12:00 AM
06 pursuit gt's Avatar
fuel pump maybe
Old Oct 18, 2008 | 07:20 PM
Coblasts's Avatar
Could be a dirty thottle body.
The throttle plate maybe sticking.
Old Oct 18, 2008 | 09:14 PM
baltracer173's Avatar
My 2.4 does the same thing and has been for awhile now. I need to give it some gas as soon as it starts or it will run rough and quit but then starts right up again fine. Deale says theres nothing wrong with it but they dont kno **** prolly
Old Oct 18, 2008 | 10:29 PM
Coblasts's Avatar
The car ignors most of the sensors when it is started cold.
I think it runs in closed loop until it senses a certain amount of tempeture change.
The throttle plate is closed tight and calibrated to zero position with the throttle positon sensor and Im thinking this might be were your problem is.
Old Oct 20, 2008 | 10:19 PM
XM15's Avatar
I'll check the TB for starters.
Could it be something with the ignition system?
Old Oct 20, 2008 | 10:23 PM
SCcobaltSS's Avatar
I had the same thing starting to happen to my car, then I cleaned my throttle body and changed plugs.... But then my TPS went out... New throttle body for me..
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
DANRICKARD
Oct 1, 2015 12:08 AM
