Trunk leaks
Old Aug 30, 2006 | 06:42 PM
cravnspeed's Avatar
Trunk leaks
Help, my speaker box sounded like crap so I open my trunk and it's soaked, there's 2-3 inches of water around my battery and spare tire. It seems to be leaking from the wing, going down the key hole, and into my floor. I actually had mold on my carpeting. Anyone else have problems and what do I do now??
Old Aug 30, 2006 | 06:54 PM
Grimlakin's Avatar
If it is still under warranty take that bad boy in!
Old Aug 30, 2006 | 07:04 PM
cravnspeed's Avatar
I have an after market system and I think it's blown, that's what got me to open my trunk in the first place. I'm sure they'll say it's my fault and won't replace anything, warranty voided or something. I'm so pissed!
Old Aug 30, 2006 | 07:07 PM
D4u2s0t's Avatar
how would a leaky trunk be your fault?? unless you drilled it or something...
Old Aug 30, 2006 | 07:11 PM
cravnspeed's Avatar
Have you ever known a company to willingly fix anything? I'm just wonderin if they'll replace my amp, it's fried, which would explain the crummy sound I've been gettin!
Old Aug 30, 2006 | 07:52 PM
Forseti's Avatar
Did you modify the wing or spoiler?
If the trunk area is still "stock" (meaning you didn't modify the spoiler/wing) you *might* be able to make a claim against your comprehensive insurance. Ask your insurance company.
You should make your comprehensive deductable as low as you can get away with...$50, $100...its usually very inexpensive, unlike collision. If it is $500, it is way too high....
Old Aug 30, 2006 | 07:54 PM
HackAbuse's Avatar
I have the same problem it seems to be leaking from the bottom... not the top
Old Aug 31, 2006 | 10:44 PM
Forseti's Avatar
Is it possible water is coming up through the battery vent hole area?
Old Sep 1, 2006 | 04:49 AM
SK63's Avatar
So far I haven't had this problem, but it seems to me like the trunk lid isn't sealed very tight.
Well, that's what I've noticed on mine anyway.
Old Sep 4, 2006 | 03:30 PM
5150studios's Avatar
I had the same problem.. Apparenlty this is a known issue, and that they will fix it under warranty..
It looks like a little hot tub back there right.. i had up to 1 1/2 inches of water at one point.. i have yet to get GM to fix it, but i did take in and and they wanted to make an appointment with that they call a "leak specialist"... Oldsskool says it is just the wash kid between smoke breaks... hahahahah
I am planning on taking it in this week while i am on vacation..
Old Sep 4, 2006 | 04:50 PM
cravnspeed's Avatar
Hey all, thanks for the feedback, my leak was from the sunroof drain, it is a tube that runs thru the trunk sides and out the bottom, it's not made of one piece and it was disconnected. GM says it's my fault cause of my aftermarket system, of course!!
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
