TSB rattling rear deck?
Okay, here;s the story. like so many rear decks in balts, mine rattles just a little bit over some bumps. MY dealer is pretty much useless (i seem to think that in florida no one wants to work on ANYTHING) because the car still pulls to the left slightly and the brakes shake a bit.
aaaaaaaaaaaanyways... i'm sure it's just some small adjustment or tightening or whatever, but sincce it's a common issue, is there a TSB on it? i've been searching here and google for a half hour, no luck.
When you say rear deck, you mean the panel right behind the seats? If so, my dealer just added some insulation on where it mounts. No TSB that I know of, but it did the trick. It was rattling bad - it sounded just like the wing when you close the truck, but inside the car.
any idea where that is exactly? cause if that's all it is, i'll do it my self.
A few weeks ago I had my stage kit installed and had them check out that noise. They called and told there was a bullitin about the monuts for the rear struts. So I had them order the parts just need to have them put in and see if it works. I will repost as soon as they do the work to keep you all posted.
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
