Tune and Reflash Question
Old Oct 9, 2008 | 02:01 PM
ikeryder13's Avatar
If you tune your pcm and reflash it back to stock can the dealer ever notice this? I know that if they find out they will void your warranty... but i wanna know because i have a stg2 right now... But i have a 2.9 i wanna put on and i will need a tune... but if i do this and something happens and i reflash back to stock then will the dealer be able to notice the reflash?
anyone?
Old Oct 9, 2008 | 02:48 PM
Dainslaif's Avatar
No, they won't.
Old Oct 9, 2008 | 02:51 PM
ikeryder13's Avatar
no way possible?
Old Oct 9, 2008 | 02:55 PM
an0malous's Avatar
Originally Posted by Dainslaif
No, they won't.
please dont listen to this guy.
yes, they can find it quite easily if they want to.
gm has even declared this in bulletins about aftermarket tuning.
does that mean bells and alarms go off if you go for an oil change?
no
but it means that if you have some kind of issue, and they decide to check out your pcm, they could use evidence of aftermarket tuning against you in a warranty denial.
Old Oct 9, 2008 | 02:56 PM
ikeryder13's Avatar
really? thanks bro... i wanna put this 2.9 on but i dont know if its worth losing my warranty
Old Oct 9, 2008 | 03:00 PM
an0malous's Avatar
its not like its an auto warranty denial....
generally if they check your PCM and all the parameters look like a GM tune, the likelyhood is that you will have no problem.
but you should be aware that if they really want to dig, they CAN detect aftermarket tuning.
thank all the idiots with diesels running those stupid "chips" and "programmers" for this.
Old Oct 9, 2008 | 06:12 PM
ikeryder13's Avatar
oh i see... well that sucks!
Old Oct 10, 2008 | 12:37 AM
rukkee's Avatar
Yep Anom is right , if you have a engine failure GM will dig . Even if flashed back to stock i read in a dealer world bulletin that they could check the flash history for dates of when it was flashed and so on.
Old Oct 10, 2008 | 01:56 PM
standan's Avatar
The answer to your question is no. GM cannot go back into pcm histroy to find refalshes. The whole idea behind reflashes is a fresh start no history. That being said if you program your pcm with aftermarket programming...something goes wrong...you reflash and its still there...they wont be able to tell if the pcm was the problem
Old Oct 10, 2008 | 01:59 PM
YellowBalt06's Avatar
you can run your 2.9 on the gm tune without a tune
Old Oct 10, 2008 | 02:06 PM
rnjmur's Avatar
The way I understood it was, GM can look at how many times the car has been flashed and compare it to the count on the PCM. If the number of times a flash has been performed doesn't match then they can void your warranty. They can also compare any value in the tune to the tune on your car and if it doesn't match they can void your warranty.
^^ Also very true. You CAN run a 2.9 on the GM stage 2 tune and it should be fine.
Supercharged06SS
Dec 11, 2022 04:47 PM
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
Extremespeed
Sep 29, 2015 04:34 AM
