Turbo????
Old Jun 30, 2011 | 05:06 PM
Mike08ss/tc's Avatar
Turbo????
Earlier this month i was at BYT place getting my car tuned. While trying to get my car tuned Nick noticed that i had a bad air leak. Pulled bypass off had alot of oil on it. Pulled charge piping off and that had alot of oil in it. I know that turbos do create oil but there is alot of oil. What could this be thr turbo seal gone bad because they is barely and shaft play. Or the turbo on its last leg.
Thanks
Mike
Old Jun 30, 2011 | 05:10 PM
Chevycobaltss3's Avatar
yOU COULD HAVE A TON OF BLOW BY. (check your compression and also check your leakage)
or TURBO SEALS ARE GOING OUT!
Old Jun 30, 2011 | 05:15 PM
what are these cars supposed to have for stock compression
Old Jun 30, 2011 | 05:16 PM
Depends on elevation!!!!!!!!
Old Jun 30, 2011 | 05:17 PM
BPacak's Avatar
Vtec Rep
Have you got a response about your platinum membership yet?
Old Jun 30, 2011 | 05:18 PM
BumbleBee's Avatar
Well i seen cobaltss.net reimbursed me once and my paypal shows it but i have yet to recieve anything for my other charge.. I did it twice because th efirst time it didnt work...
Old Jun 30, 2011 | 05:24 PM
Yep just looked again it shows i paid for two i got reimbusred for one but the other cobaltss.net still shows of taken my money!!!
Old Jun 30, 2011 | 05:25 PM
BPacak's Avatar
Vtec Rep
pm speedlimit and tell him the situation, he should be able to work it out.
Old Jun 30, 2011 | 07:46 PM
Coblasts's Avatar
Guessing here but could be a intake manifold gasket leak,I think the earlier SC 's had that problem until they came out with the new gasket.
If the compression is good try replacing it.
Old Jun 30, 2011 | 07:50 PM
05Slowline's Avatar
except he's not an sc lol
Old Jun 30, 2011 | 08:01 PM
Coblasts's Avatar
So your saying a turbo doesnt have a intake manifold Then ?
If your not going to help how about keeping your smart ass remarks to yourself!!!
And adding lol behind everything doesnt make it funny!!!!!lol
Old Jun 30, 2011 | 08:06 PM
JacBlackSS/TC's Avatar
just do the compression and leakdown test thats the only way to know for sure
but when i was getting my turbo replaced i actually called borg warner and they said that our k04 doesn't have seals on it.....idk sounded strange but they are the ones that make it so who knows
but is the car blowing any kind of smoke???
Old Jun 30, 2011 | 08:37 PM
05Slowline's Avatar
your statement only pertained to a car 4 years younger which isn't applicable to the op's car don't get your panties in a bunch
Old Jul 2, 2011 | 09:58 PM
car smokes when nls. It holds boost all the way through. The leakdown test what do you mean buy this.
Old Jul 3, 2011 | 12:43 AM
cobalt2010's Avatar
theres really two types, one if your not holding compression you will put a drop of oil in the cylinder. then test again. thats only if you have low compression on said cylinder. you then know if it holds that you have blowby on you
the other one is an air leakdown test. in a way the same as a compression test but you pump a certain amount of air in the cylinder then shut off your air supply at a certain psi, then watch said guage to see how fast it leaks out. or get an air leakdown guage.
i dont know which they were referring to. but i hope this helps
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
