Turn signals
Old Mar 26, 2008 | 01:33 AM
KyleMinnis's Avatar
your blinker is out...(its happend to me once already)
Old Mar 26, 2008 | 01:34 AM
REIGN SS's Avatar
Original Hayden Fanatic
Originally Posted by Bumblebalt
goes back outside*** lol hold on
well the back does absolutely nothing, any fuses i can check?!
There is a fuse in the box under the hood, but it is most likely just the bulb: replacement # 3157, any autoparts store should carry them
Old Mar 26, 2008 | 01:35 AM
Bumblebalt's Avatar
im gonna tottaly newb out here and say, the back bulb is lighting up fine, so which bulb is out or going out? the front or the back?
thx on the info, im hoping its just that!
Last edited by Bumblebalt; Mar 26, 2008 at 01:35 AM. Reason: Automerged Doublepost
Old Mar 26, 2008 | 01:37 AM
REIGN SS's Avatar
The back bulb blinks, or just lights up b/c the headlights are on?
h0l0caust's Avatar
my car is going in for a oil change tomorrow, my blinker bulp is also gone....my blinker arrrow is gone wildddddddddddd.
Old Mar 26, 2008 | 01:41 AM
Bumblebalt's Avatar
the back bulb just lights up bc the head lights are on, but does nothing.
Old Mar 26, 2008 | 01:49 AM
REIGN SS's Avatar
hmmm, you could check the fuse under the hood, but it probably needs a new bulb... Replace the bulb and see if that fixes it
Old Mar 26, 2008 | 01:51 AM
Acey's Avatar
Balts have a dual filament (one running lamp one break/turn) rear bulb like the Cavy, correct?
Old Mar 26, 2008 | 01:54 AM
REIGN SS's Avatar
Probably, I know the headlights do, wouldn't surprise me if the tails do too
Old Mar 26, 2008 | 01:55 AM
Bumblebalt's Avatar
right on, ill give that a go in the morning! i'll post with updates.
Old Mar 26, 2008 | 02:03 AM
  #36
Acey's Avatar
Thanks Reign... and yeah to the OP my left side started blinking fast the other day and I assumed it was a blown bulb but since I'm always messing with the wiring in my car I always hope to not **** something up. The signal filament of the front marker was blown, and a quick Wal-Mart trip was the remedy.
Old Mar 26, 2008 | 03:02 AM
  #37
Bumblebalt's Avatar
the signal filament, what exactly is that?
Old Mar 26, 2008 | 11:12 AM
  #38
Bumblebalt's Avatar
https://www.cobaltss.net/forums/problems-service-maintenance-69/right-rear-signal-wont-work-front-right-signal-flashes-really-fast-101559/
found it!
Old Mar 26, 2008 | 04:55 PM
  #39
Acey's Avatar
There are two filaments in the bulb itself. One lights up with the running lamps and is less bright, the other is your actual turn signal, which might be prone to blowing sooner if you have a pre-07 Cobalt because that filament is on at full intensity as a daytime running lamp.
Old Apr 4, 2008 | 05:37 PM
  #40
blackjack hotrods's Avatar
I HATE daytime running lamps!
Blame Canada!
LOL
Old Apr 4, 2008 | 05:43 PM
  #41
Acey's Avatar
^^ Just turn them off. Personally, I like 'em... I'm in the process of disabling the headlight DRL's on my Cavalier and switching them to the turn signal cause that looks cooler.
Old Apr 4, 2008 | 06:00 PM
  #42
That's what I plan on doing with my Cobalt. When I had a Silverado I rewired the DRL's so that they ran on the dim filament in the bulb and then put amber bulbs in there. I was the only silverado around that didn't have one buned out DRL and one bright-as-the-sun DRL.
Old Apr 4, 2008 | 10:21 PM
  #43
Acey's Avatar
^^ Nice. I tried to go Audi R8 style with white LED's as DRL's (see thread: http://www.oznium.com/forum/topic16571) but they're not bright enough. Turn signals it is.
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
roth
Sep 26, 2015 12:16 PM
