URGENT: Car won't start help!
Old Mar 17, 2012 | 11:38 PM
aquaman3680's Avatar
Hey,
So I was working on the car today and decided I wanted to install my LEDs for the driver and passenger under the dash, no biggie right? Well for whatever stupid reason I decided to tap power off of the DIC button panel, thinking that it comes on when I would want the lights to come on so why not?
So after getting it all wired in, I turned on the car and attemped to start but nothing, check engine light is on, so I unwired the LED's from this and wired it back together with nothing attached, and it still will not start. Has anyone experienced this before or know what could be the issue?
Here are some pics just to give you an idea.
Any help would be much appreciated, I NEED it lol been a long day.
Thanks,
Matt
Old Mar 17, 2012 | 11:48 PM
It's a 2006 SS 2.4L, forgot to say that in the first post.
Thanks,
Matt
Old Mar 17, 2012 | 11:58 PM
AzraelRaezier's Avatar
try disconnecting the negative terminal on the battery for 10 mins then rehook it up. only thing i can think of.
Old Mar 18, 2012 | 12:03 AM
CannonBalt's Avatar
Your theft light is on, maybe that has something to do with it.
Old Mar 18, 2012 | 12:08 AM
SunburstSS's Avatar
you prolly blew the tachometer fuse or some other one, i believe the tach and a bunch of other stuff uses a specific fuse, check ur owners manual budd, im far away from it so cant help u with the rest of details
Old Mar 18, 2012 | 12:10 AM
That's kind of what I was thinking, I mean I had been working on the car all day, doors open most of the time, and started it up several times to back in and out of the garage. It turned over a few times at first and then after trying different things got to where it would attempt to turn over but nothing. I'm starting to think I drained the battery, I mean I have tried everything. I'll try unplugging the negative terminal and if nothing I'll try jumping it. It doesn't make sense that the CEL is on though. I've gotta go to work in the morning, hopefully I can get something to work!
Thanks for the replies.
Matt
Old Mar 18, 2012 | 12:18 AM
is your car a stick? you could always get it rolling (3-5mph) and dump the clutch to fire it up and charge the battery with ur alternator.
Old Mar 18, 2012 | 12:24 AM
I wish unfortunately its an auto.
Looking through the manual now to see what I can find.
Old Mar 18, 2012 | 12:37 AM
try the battery thing i mentioned and give it a try.
Old Mar 18, 2012 | 12:45 AM
Will do, Ill do that first thing when I wake up, gotta go to bed, work in 6:30 hrs.
Old Mar 18, 2012 | 12:58 AM
insylem's Avatar
This is what I was thinking too
Old Mar 18, 2012 | 01:00 AM
insylem's Avatar
Keep in mind for this to work the battery cant be completly dead.
In order to push start your car..
The Battery must power
  1. Fuel Pump
  2. PCM
  3. Sensors
  4. Fuel Injectors
  5. Ignition Coils
  6. Alternator Exciter Field
07LSJ's Avatar
That's happened.to me a couple times. I just un plug the battery
Old Mar 18, 2012 | 01:01 AM
insylem's Avatar
You might have blown a fuse somewhere
Old Mar 18, 2012 | 01:03 AM
BlkWdoSS's Avatar
battery is dead, CEL is on because it is always on when you go to start your car... it then goes off once the car is started
l8r,
PD
Old Mar 18, 2012 | 12:08 PM
  1. Fuel Pump
  2. PCM
  3. Sensors
  4. Fuel Injectors
  5. Ignition Coils
alright well idk what to tell you to that. my battery has been dead to where it wouldnt crank my car but i got it to push start. so i guess maybe it still had enough juice to power those other things?
Old Mar 18, 2012 | 12:44 PM
Jumped the car and everything is working fine. Thank you for the help and responses!
Matt
Old Mar 18, 2012 | 12:45 PM
Dontstoprunning's Avatar
Matt
Old Mar 18, 2012 | 12:49 PM
insylem's Avatar
I dont know how much Juice it takes to run all those things though. But the starter does take the most ammount. So ya, its possible that with your battery dead/low that if it still has the power to run those things it will still pushstart. I had a dead battery once where I could not push start it because it wouldn't run all those things. Also happened with a friend of mine's pickup truck once too.
Old Mar 19, 2012 | 01:17 PM
Chevrolet Cust Svc's Avatar
Matt
Sounds like it was a rough Sunday for you Glad that everything's running again!
Best,
Sarah
GM Customer Service
Old Mar 19, 2012 | 01:20 PM
K-Train04RL's Avatar
Pass lock it on. Keep key in on position for like 10 mins then try again. Have a nice day
Old Mar 19, 2012 | 01:30 PM
bamaboy22's Avatar
its a theft issue. if the battery dont work. turn key to run position for exactly 10mins. then turn off and back to run within 5 seconds, wait another 10mins. turn off then back to run 10mins off key out back in crank
Turbo Johnny
Feb 21, 2019 09:41 AM
How to Guide
57
Oct 15, 2015 11:56 AM
hawkssoccer11
Sep 30, 2015 12:14 PM
Wind
Sep 11, 2015 06:57 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
