USB radio problems
Old Aug 6, 2009 | 11:07 AM
lotusdork's Avatar
USB radio problems
Anyone having any issues with their USB connection on the radio. I have an 09 SS sedan. My 3rd gen Nano gets power but the head unit will not connect. I got a USB flash drive to work for about 10 minutes and then the head unit said it lost connection. I pulled out the flash drive and it burned my hand. Apparently it was hot enough to melt some of the case on the flash drive. Any thoughts?
Old Aug 6, 2009 | 09:43 PM
Gene Culley's Avatar
#08-08-44-032: Newest Generation of iPod and iPhone Will Not Connect to Radio, Device Not Authorized Message Displayed (Reprogram Radio) - (Dec 10, 2008)
Subject: Newest Generation of iPodŽ and iPhoneŽ Will Not Connect To Radio, "Device Not Authorized" Message Displayed (Reprogram Radio)
Models: 2009 Chevrolet Cobalt
2009 Pontiac G5
with USB Port Equipped Audio System (RPO UUI)
Attention: This service bulletin only applies to radio part numbers 20758187 and 20758188.
Condition
Some customers may comment that their new iPod and iPhone will not connect to the radio and a "Device Not Authorized" message may be displayed. The devices affected are the following:
• 1st Generation iPod touch (with latest firmware)
• 2nd Generation iPod touch
• 4th Generation iPod nano (8gb or 16gb)
• 5th Generation iPod video (30gb or 60gb with latest firmware)
• iPhone (with latest firmware)
• iPhone 3G
Cause
This condition may be caused by a software anomaly.
Correction
Do This
Don't Do This
Reprogram the radio with updated software.
Do not replace the radio.
A revised calibration has been developed to address this condition. Technicians are to reprogram the radio with the latest software available on TIS2WEB. Refer to the Digital Radio Receiver Programming and Setup procedure in SI for more information. As always make sure your Tech 2Ž is updated with the latest software version.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
R0759
Radio Reprogramming with SPS
Use Published Labor Operation Time
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
Š 2009 General Motors Corporation. All rights reserved.
Old Aug 6, 2009 | 09:52 PM
northvibe's Avatar
yeah bring it in. my HU works with my 3gphone, ipod mini, iphone 2g, ipod shuffle. wow it melted a usb drive case? yikes, bring that in with this tsb printed.
Old Aug 7, 2009 | 10:19 AM
lotusdork's Avatar
Thanks for the bulletin. I'm planning on taking it in next week.
Old Aug 8, 2009 | 10:42 PM
Talking
NP man, good luck. Report back
Old Apr 2, 2014 | 08:47 PM
comptech2's Avatar
I had the same issue with my USB drive and I found out that the radio does not like high density flash storage try using an older flash drive because more new drives are high density I went to a 2gb I had laying around and it works but little space I'm going to try to hook up an external hard drive to see if that works too
Old Apr 6, 2014 | 09:57 AM
2010Cobalt's Avatar
i have a 2010 cobalt LT but it came with the pioneer package. I found its my iphone not my car, apple is dumb, i just reset my phone and it works.
OFF TOPIC: my passenger front tweeter is coming in and out, just started. the car is 4 years old with 51k. ive had it since the get go, i never run the radio above half volume and my bass/trebles settings are not maxed. you guys think the speaker is blown or has anyone actually had wires become unplugged? im feeling its probably blow which is a bummer
Old Apr 6, 2014 | 02:37 PM
YelloEye's Avatar
I'm running a
Sandisk Crusier Fit 32gb Sandisk Crusier Fit 32gb
drive just fine.
turbochargedss2012
Sep 20, 2023 12:17 PM
agentirons
Oct 16, 2015 02:11 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
