Vibration in gas pedal
Old Dec 5, 2007 | 07:50 PM
1fastcobalt's Avatar
I have a vibration in the gas pedal all the time. This is the only place i can feel it. Car rides smooth. If im cruising and driving normal it has a buzzing , vibrating feel in the pedal. When i let of the gas and coasting out of gear the feeling is still there. The only other thing i noticed is at high speeds when i'm accelerating the car seems to shake a little. Anyone have a clue what this is.
Old Dec 5, 2007 | 07:51 PM
stealthy1ss's Avatar
Do you have mounts or springs?
Old Dec 6, 2007 | 10:15 AM
fsickness's Avatar
Are you coming up with a code? Mine is doing the same thing...coming up with p0300 and been to the dealership 7 times and they can not figure it out.
Old Dec 6, 2007 | 10:17 AM
BLAZIN07SS's Avatar
I'm too JDM for you
p0300 is random cylinder misfire. try switching to NGK BRK7E's gapped at .38
It fixed the problem for me
Old Dec 6, 2007 | 10:18 AM
Dead Zen's Avatar
ummmmm. i thought our cars were drive by wire, hence no mechanical connection to the throttle body so there should be no vibes. maybe im just dumb???
Old Dec 6, 2007 | 10:27 AM
MTPockets's Avatar
I know, you'd thing that would be the case. Thankfully I don't have this issue with my Cobalt, but my Trailblazer was throttle by wire and had the vibrating gas pedal. It would literally make your foot fall asleep on long highway runs. All I could figure is it had to do with how the pedal support is tied into the body.
Old Dec 6, 2007 | 11:57 AM
fsickness's Avatar
I know what the code is and I have changed out my plugs twice...but no go. And a misfire would make the car jump and feel vibrations and there are multiple things that can cause a misfire not just plugs.
Old Dec 6, 2007 | 07:35 PM
Vibrating
No i'm not getting a code. I feel its feedback through the floor but the other pedals are not vibrating. This is very strange and aggrivating
Old Dec 6, 2007 | 07:44 PM
spiderbite's Avatar
mine does the same thing, i haven't got a clue what it is. i also hear what i can only describe as a soft grinding sound every now and then. it only lasts a few seconds but it has me wondering. i tried to describe it to my step-father but he said he wouldn't know until he drove it and witnessed everything for himself, which has yet to happen.
Old Dec 6, 2007 | 10:12 PM
RaineMan's Avatar
my pedal vibrates like hell... but I've got solid mounts...
Old Dec 24, 2007 | 12:05 PM
jsscooby's Avatar
my does it, since new, very annoying, sometimes if I mess with the tire pressure it will help. I also test drove an LT and it did the same thing
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
Tupp
Sep 30, 2015 08:18 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
