Warranty questions - Problems
Old Aug 12, 2007 | 12:05 PM
HitanApex's Avatar
I have one year and 16k left on my bumper to bumper warranty.
1. My alignment is off, I doubt they will do that. Any tips on talking them into it?
However,
2. My air controls stopped working, no heat, no air on windshield, only cold air in my face - they have to fix that.
3. One of my headlights has condensation inside it - I assume that is covered.
4. Finally, on my stock radio, one of the buttons is starting to flake - 2 years later? This is unacceptable! Will they entertain putting another stock radio in for me under warranty?
5. The plastic piece around my window switches on the driver side door panel is showing bag signs of age (paint is flaking). I have read here that is covered.
Any experiences/tips would be appreciated, thanks!
Old Aug 12, 2007 | 12:09 PM
DTM2188's Avatar
1. Alignment was covered for me.
2. Air controls are definatly covered.
3. Headlights condensation is covered as long as you didn't paint your housing.
4. My stock radio was flaking on two buttong (real small spots) and I got a new one under warranty.
5. Should also get new ones under warranty.
Old Aug 12, 2007 | 12:14 PM
jgarciarivera's Avatar
1. For me it was not covered. It's supposed to be the owner responsability.
2. Covered
3.Covered - They changed them because of condensation
4. Covered
5. Covered - The same part arrived at my dealer and will be changing them on the 24th
Jose
Old Aug 13, 2007 | 07:42 PM
srtbrad's Avatar
Canadian Warranty: could be slightly different
1) - customer should perform thrust alignment once every year, however, r&r of steering gear, control arm bushings, sway bar links etc. include a set toe. - complain of a clunk over bumps. - you should end up with a free alignment.
2) HVAC controls are always covered. the defrost is considered part of safety
3) Common problem, always covered. (with no signs of damage)
4) Radio will be swapped for a new one, there is no way to fix those buttons, also always covered.
5) Common problem, always covered with no signs of damage.
brandon04
Oct 21, 2015 07:04 AM
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
