Water in driver's side headlight
Old Aug 25, 2011 | 04:58 PM
dmeine13's Avatar
Very busy lately.... going to get the stealership to fix this. about how much should it run me to fix? The dealer said i need a brand new headlight housing.... but shouldnt i just need a new seal?
Old Aug 25, 2011 | 07:16 PM
dmeine13's Avatar
Old Aug 25, 2011 | 07:19 PM
heathkidder's Avatar
you could actually do it urself but if the dealership would just give u a new one then why not....all u gotta do is pretty much take the bulb out and dump the water out. then let it either sit in the sun or use a blow dryer and put it in the hole till its gone. but iv found to let it jsut sit in the sun is better. then go get some clear sealant and go around the stock stuff
MastaShaKe_88's Avatar
They don't do all that resealing madness, they'll jus get you a new one if it's the stock headlight
Old Aug 25, 2011 | 07:22 PM
BurntMarshmallow's Avatar
Take you headlight and stick it in the oven for about 15minutes on 200c. press it back togetherr and use some clear cocking around the outside to seal it. you might need to fully take the headlight apart to whipe inside of it but other then that its the easy 10 dollar fix.
Old Aug 26, 2011 | 09:21 AM
whoa whoa... if you got some extra cocking to do, I would use it all up on a cobalt headlight that just came out of a 200ş oven... Now a Vette headlight...
Old Aug 28, 2011 | 09:43 PM
dmeine13's Avatar
haha thanks for the advise guys. im going to take advantage of the situation and use it as an excuse to get myself some gen 4 projectors and throw on an hid kit
Old Aug 29, 2011 | 06:36 AM
insylem's Avatar
What about drilling a small drain hole in the bottom?
Old Aug 30, 2011 | 09:17 PM
dmeine13's Avatar
Wait so I can just take the bulb out and let it out that way? I don't have to take off the lens?
Old Aug 30, 2011 | 09:20 PM
bamaboy22's Avatar
Winner! This is what gm will do if you don't wanna buy one. Small hole in the bottom and let it drain.
Old Aug 30, 2011 | 09:44 PM
SedanMan08's Avatar
Yes.
Old Aug 31, 2011 | 03:27 PM
dmeine13's Avatar
last question! can i use some sort of adhesive like super glue to go over the stock sealing? or should I use silicone
Old Aug 31, 2011 | 05:39 PM
SedanMan08's Avatar
No superglue. Silicone is best. I just use the permatex sealant 3oz tube from autozone.
Old Aug 31, 2011 | 07:16 PM
Rocky87's Avatar
hell no, when you wash your car it will fog up
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
Tupp
Sep 30, 2015 08:18 PM
