water in light houseing
got some light condensation goin on in the front right headlight....any tricks to get rid of this or do i have to take the whole thing off and reseal it cuz itll **** up my HID's im sure if i dont act now...pretty sure its only cuz of the cold to cuz it didnt do this during the summer and fall
its not like its alot of water either. over the summer it rained and never retained any water at all its lik a bit of a fog and condensation on it and its not to bad jus annoying to look at u know
Take the light inside your house, use a hair dryer to dry it out. let it sit for a bit with the bulbs out so you dont trap hot air inside. Then put the bulbs back in and re-install in car.
I did that over a month ago when the weather changed, and its been fine ever since.
If you are really against taking them apart, you could seal around the headlight, and the black rubber piece where the main light bulb goes. Then just pray you got it sealed. You will have to let it dry out first
