Water on the passnger floor
Old Aug 25, 2007 | 12:11 PM
PinkStripedCobalt's Avatar
While driving home from the KC meet water started dripping on my foot around the gas pedal area, well i didn't think anything about it since it stopped, and the guys told me it was from me having the ac on and the windows down......so yesterday i come out of work get in the car and look over at the passenger side floor to pick up a cd that fell when i picked up the cd it was wet i was all confused so i touched the floor and it was soaked.......
So what could be wrong????? I thought it could be the sunroof seals or the door seals but the seats aren't wet, just the floor, and just the passenger side floor......
Please help......any ideas?????????????
Old Aug 25, 2007 | 12:13 PM
lucky_lellow06's Avatar
That's the only thing I would have thought it was.
Your car isn't a female, right? She doesn't just randomly start leaking, right?
Old Aug 25, 2007 | 12:21 PM
Kritter's Avatar
GM is notorious for this issue, I see it all the time when I change windshields out. Most likely what it is hat's leaking is the cabin fresh air intake. It sits drectly under the passenger side of the windshield, in the firewall, and what is happening is the drainage holes around the fresh air intake are clogge, and water is instead finding it's way down through the intake, which drops right into your passenger floorboard. THis is huge problem in the last generation Impala, monte carlo, malibu, etc. All you need to do, should this in fact be the case, is blow the drain hoes out and you'll be good to go.
And I'll say this just because I hear from customers all day long. It IS NOT the windshield leaking in order for t to be a windshield leak, water would have to travel down the glass, then back up under the glass, through the urethane sealant and under the dash....Physics alone makes this impossible, unless you're going about 200+MPH. Anyone who has ever had a job replacing windshields can back me up on this.
In the end, I'd check that cabin intake, just pull the wipers off, remove the cowl and look on the the passenger side, and you'll see what I mean. If you want, take some pics, and pm them to me, or email, and I'll take a look for you.
Old Aug 25, 2007 | 12:25 PM
hatrickstu's Avatar
i had to take mine in 2 weeks ago for the same thing. its going to be a leaking heater hose, warranty fix
Old Aug 25, 2007 | 12:27 PM
I'm talking there is a lot of water.......will the replace my interior because its starting to smell!!!! Its been so hot, i have my windows open.....i have an appointment on tuesday for my sunroof switch
Old Aug 25, 2007 | 12:31 PM
Kritter's Avatar
If i's the heater hose like hatrick said, they should indeed replace the interior, although you may have to push for it...If it's the fresh air intake, probably not, but if you push em hard enough you may be abl to get them to do it.
Old Aug 25, 2007 | 12:38 PM
O i will get it haha....i usually get what i want I'm getting new interior no matter what the issue it is....I kinda pisses me off first the sunroof which i have been having problems with since i got the car now water
Old Aug 25, 2007 | 12:50 PM
Kritter's Avatar
Sunroof button bezel Im guessing?
Oh, not to thread jack ya, but I'll be posting somehing up in KC thread here shortly, something you may come back dow here to be at.
Old Aug 25, 2007 | 12:53 PM
yes!!!!!!! Yes it is Damn the sunroof bezel!!!!!
Haha i'm not driving back there until next summers meet unless there is a very good reason haha!!!!
Old Aug 25, 2007 | 12:56 PM
Kritter's Avatar
Road course set up on an airport tarmac good enough for ya?
Old Aug 25, 2007 | 01:00 PM
kjn24's Avatar
this has happened to me but only when it rains HARD.
Old Aug 25, 2007 | 01:05 PM
i don't race right now, nothing done to my car yet!!! haha Pick me up at the airport i'll fly haha!!!! But would be cool to watch forsure!!! I didn't see the post
Which guy are you the one that we didn't know whose black balt was in the hotel parking lot???
I also thought it was from the rain but it hasn't rained in 24 hours!!!!!! so its not the rain....
where is Logan, Ohio????
Last edited by PinkStripedCobalt; Aug 25, 2007 at 01:05 PM. Reason: Automerged Doublepost
Old Aug 25, 2007 | 01:18 PM
Kritter's Avatar
ok, posted it up now...Wasn't at the meet, was out of town on business
Old Aug 26, 2007 | 02:04 PM
kanban's Avatar
ITS COMING FROM YOUR DOOR WHEN IT RAINS, I HAD THE SAME PROBLEM, GM RESEALED THE DOOR NO MORE PROBLEMS 2005 SS/SC ARE BIG ON THIS PROBLEM CHECK YOU RECALL/ NOTICE BULLENTIN BOARD
Old Aug 26, 2007 | 02:09 PM
Coblt ss super's Avatar
it could also be the drain hose from the sunroof got kinked or cloaged (i dont know how to spell it so bear with me) that is wat happened to me, warrenty fix!!!
Old Aug 26, 2007 | 03:14 PM
Kritter's Avatar
THe drain hole for the sunroof would cause it to leak in the headliner, not the floorboard
Old Aug 26, 2007 | 04:25 PM
nope floor too, mine dripped from the sunroof, couldnt go no where, then trickled down the pillar and down near the passenger speaker and came onto the floor from there
Old Aug 26, 2007 | 05:07 PM
Evilfrog's Avatar
The sunroof has 4 drain ports. All of those attack to 4 rubber hoses. Two hoses run through the front pillars. and two run twards the back of the car. If any of those hoses develops a crack it could leak anyway. If one of the hoses pops off it would drain on the headliner.
But the sunroof also has a seal round the outside. So water would have to get into that the car first.
Old Aug 26, 2007 | 05:14 PM
jgarciarivera's Avatar
I had almost the same issue. Water started to pour on the passenger side. I took it to a dealer and they adder an elbow hose at 90 degrees. It is like if the water returns from the drain. Just my thoughts
Jose
Old Aug 26, 2007 | 05:18 PM
Ron From Jersey's Avatar
Could also be a clogged drain tube from the A/C
Old Aug 27, 2007 | 07:45 PM
Area47's Avatar
Rent me! per hour
yepo. that was my guess.
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
nathan112i
Sep 30, 2015 07:12 PM
Slick_Nick
Sep 28, 2015 09:15 PM
