Way too much gunk in throttle body/Supercharger..NOT good
I've been noticing the pronounced stuttering while accelerating and deaccelerating in first and second, sometimes even third. After researching my ass off on the topic (yay me), I decided to take off the throttle body and do some major cleaning. Well, the throttle body was near black when i took it off. I made sure not to move the butterfly valve, and cleaned with a cotton rag and q-tips. Got it spotless and shiny and then I went to put it back on the supercharger. Well, what I saw was NOT good. Inside the supercharger there was even more gunk and dirt, all of which looks like it more than likely has been entering my engine, causing the amount of black soot crap on the innside of my exhaust tip.
Heres the photos, where the dark line is is basically as far as I could get my hand inside to clean.
Should I be worried? Should I halt driving until I can pull the supercharger and clean it? I noticed today my driver's side wheel well plastic has a very substantial crack in it, to the point where there is a hole. Thus my intake w/ airbox mod could be sucking up more than just air. Just not sure where to go from here..
When you say clean do you recommend pulling the supercharger off, disassemble, full clean, and reassembly? I would then have to re oil the supercharger, correct? Or should I leave how I've cleaned it in the pictures and call it a day, checking in the future for more build up around the TB?
Have you cleaned the supercharger? Do you recommend it as well, or should I just leave it and stick with cleaning the TB every year?
A little over 43k, I didn't know if I should be worried about sucking all that crap in the motor
I usually just clean my TB and the very start of the inlet of the blower. In your case, you can clean up your supercharger. Wont hurt anything.
Comes with everything you need:
- tube/pump to remove used blower oil, & to inject new oil.
- new genuine eaton coupler (prob should look into the zzp coupler though).
- snout reseal
You could prob rig something up with a turkey baster, and a piece of hose to remove/inject the blower oil.
If you can, you won't need to buy the kit, and will prob save money. I wanted to give ya some options.
Yep, I remember the bulletin on this.
Thanks for the tip! That's interesting, I'm gonna have to find that thread and read through it!
Thanks for the info, what differs between the zzp and eaton coupler variants?
How many miles do you have?
The kit they sell is on E-bay for like $40.
- snout reseal
- snout reseal
