weird problem
Old Mar 1, 2009 | 07:16 PM
jamiep101's Avatar
weird problem
well here is whaat happened i was on the on-ramp getting on the highway and came on to her i just about hit the rev limiter in 3rd and all of a sudden it started cutting in and out and bogging out?. i tryed to drive but it was cutting in and out pretty bad not wanting to run then after a few seconds it just started workin normal again and has not happened again sense then. anyone know what may have happened??
Old Mar 1, 2009 | 07:19 PM
fzn14's Avatar
Mine does the same thing cause of the cold air.....No worrys
fzn14's Avatar
Old Mar 1, 2009 | 07:22 PM
07BaltSS/SC's Avatar
What are your mods?
Never say its because of the cold air that makes no sense and do you have proof?
Last edited by 07BaltSS/SC; Mar 1, 2009 at 07:22 PM. Reason: Automerged Doublepost
Old Mar 1, 2009 | 09:21 PM
DarkSergeant's Avatar
Our SS/SC has done this a few times when I've really gotten on it. I've had it pure ass die on me before, had to let it set for a minute then restart it.
I just chalked it up to overactive fuel cutoff at redline..
Old Mar 1, 2009 | 09:34 PM
fzn14's Avatar
Um no actually proof..But my thinkin is that with the air being colder(denser) is has to do with the timing and what not...Anything above 40* and it never does it...really not a huge issue i think.
fzn14's Avatar
Old Mar 1, 2009 | 10:19 PM
Permafried-'s Avatar
I'm driving around here in super sub-zero temperatures (as are my friends with the SS SC) and none of us run into this when getting hard on it even when there's ice building up on the grills .
Did the DIC report power reduced or give you any visual indication the chip picked up something out of the ordinary? DarkSergeant's thought makes sense, particularly if the engine temporarily flooded or somehow became starved for fuel.
Permafried-
Old Mar 2, 2009 | 02:00 AM
fzn14's Avatar
Everything reads out normal..Hints why i am not gonna get to crazy about this little issue...It winter time so i shouldnt be gettin on it anyways lol
Old Mar 2, 2009 | 04:52 PM
jamiep101's Avatar
yeah that same thing has happened to me in the summer i freaked lol. but my mods are just a cold air intake and a gmpp exhuast
Old Mar 2, 2009 | 05:14 PM
JTob's Avatar
You were just about to hit the rev limiter, or you did hit the rev limiter. Because that sounds like normal fuel cutoff to me lol.
Old Mar 2, 2009 | 06:16 PM
jamiep101's Avatar
no i did not hit it. i don't like bouncein it off the rev limiter
Old Mar 2, 2009 | 06:47 PM
Snakes709's Avatar
mine does that alot too and only in the cold weather...so maybe it is cold air
Old Mar 2, 2009 | 10:49 PM
jamiep101's Avatar
yeah that must be it
Old Mar 3, 2009 | 01:13 AM
fzn14's Avatar
Its the car way of saying..."dont run me hard...its to ****** cold LOL"
Old Mar 3, 2009 | 04:49 PM
jamiep101's Avatar
lol ur probely right
Old Mar 3, 2009 | 04:58 PM
rnjmur's Avatar
Sometimes the tachometer is "behind" the actual engine speed. If your cutoff is at 6500 it is possible to hit 6400 and maybe even 6300 on the tach but the engine speed actually be at 6500 and then fuel cut off. Of course, once you reduce speed the fuel cut off should go away. The only way to know for sure what would be going on would be to trya nd get some logs when it happens and see if one of the injectors maybe causing a problem, whether the car is actually hitting fuel cutoff, or if you are getting knock or any other multiple issues.
I can say, I have never had my car do anything like this unless I accidently hit the rev limiter. As soon as I shift the car drives fine though...
Old Mar 3, 2009 | 05:36 PM
fzn14's Avatar
When this happened we sent a data log to Vince(my tune guy) and said all looks normal and that its just the cold weather
Old Mar 4, 2009 | 08:41 PM
cobaltR's Avatar
Was the car in normal operating temperatures? I've had this happen once...I didnt let my car warm up properly and that was the result I got for getting on it in cold weather. Its pretty much a no no.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
