weird whining
weird whining
this isn't coming from the engine bay. i can hear it all the time in the cabin of the car. when i try to hear around for it, it sounds like it's coming from around the rear axal. Do our fuel pumps tend to whin at all? if not has anyone else ever had this problem
doesn't seem to be effecting anything. the sound is just starting to get to me.
ideas?
ideas?
its loudest at idle. seems to quiet down when i hit the gas. if i'm still moving and put it in netural the noise comes back.
don't think that it has anything to do with the tranny since i'm not having any problems with the shifting
The fuel system uses the fuel filter as a bypass style regulator, it has one in and two outlets, so the pump normally runs pretty close to full blast, with the extra passing through the filter and back into the tank via the pressure regulator on the pump assembly. If it's not an AC Delco filter, I would change it for one and see if the noise continues. If it does, you may have gotten some crap inside the tank and it finally worked its way into the pump, no option there but to replace the fuel pump or deal with the noise.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Neither of those is near the rear axle...
