weird whining
Old Mar 11, 2009 | 07:17 AM
kristen's Avatar
weird whining
this isn't coming from the engine bay. i can hear it all the time in the cabin of the car. when i try to hear around for it, it sounds like it's coming from around the rear axal. Do our fuel pumps tend to whin at all? if not has anyone else ever had this problem
doesn't seem to be effecting anything. the sound is just starting to get to me.
ideas?
Old Mar 11, 2009 | 08:07 AM
Black08SSTC's Avatar
possible throw out bearing in trans??
when we gunna have a jim thorpe meet again??
Last edited by Black08SSTC; Mar 11, 2009 at 08:07 AM. Reason: Automerged Doublepost
Old Mar 11, 2009 | 08:24 AM
hawlyns711's Avatar
does it i get louder with increased speed? under what conditions do you notice it the most? could be a wheel bearing
Old Mar 12, 2009 | 06:46 AM
kristen's Avatar
its loudest at idle. seems to quiet down when i hit the gas. if i'm still moving and put it in netural the noise comes back.
don't think that it has anything to do with the tranny since i'm not having any problems with the shifting
Old Mar 16, 2009 | 01:00 PM
kristen's Avatar
Old Aug 9, 2014 | 12:58 PM
unijabnx2000's Avatar
resolution ?
Old Aug 9, 2014 | 01:49 PM
tuned08ss's Avatar
Tob or input shaft bearing
Old Aug 9, 2014 | 01:50 PM
Neither of those is near the rear axle...
Old Aug 10, 2014 | 10:28 AM
reddragon72's Avatar
Look through all my posts. I have one of the fuel pump whining.
See if it matches what your hearing.
Old Aug 10, 2014 | 10:34 AM
ItalianJoe1's Avatar
Sounds like a fuel pump issue. Does it change if you have a full tank as opposed to an empty tank?
Change your fuel filter in the last 30K miles?
Old Aug 10, 2014 | 10:36 AM
Mine didnt whine until after I changed the fuel filter (3 days ago)
Old Aug 10, 2014 | 10:43 AM
OEM filter? It's possible it's flowing too much/too little causing the pump to operate in a different speed range and now it's at a frequency where it makes noise.
The fuel system uses the fuel filter as a bypass style regulator, it has one in and two outlets, so the pump normally runs pretty close to full blast, with the extra passing through the filter and back into the tank via the pressure regulator on the pump assembly. If it's not an AC Delco filter, I would change it for one and see if the noise continues. If it does, you may have gotten some crap inside the tank and it finally worked its way into the pump, no option there but to replace the fuel pump or deal with the noise.
Old Aug 10, 2014 | 10:59 AM
Yes OEM filter.
It started making the noise next time it was driven, but no more gas was added until the following day.
Old Aug 10, 2014 | 11:43 AM
SINISTER's Avatar
Whining?
probably his wife or girlfriend...
Sl0wbaltSS
Nov 21, 2018 11:11 PM
jcarroll53
Sep 24, 2015 07:43 PM
RyGuy
Sep 21, 2015 10:03 PM
ashalle2
Sep 16, 2015 10:36 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
