What could cause my plugs to do this???
Old 01-11-2011, 03:18 PM
bigblock2.4's Avatar
I have a misfire on cylinder 4 and I have been trying to figure out whats going on. I am stumped. Not a coil and I tried new plugs.....I have only had my plugs in it for maybe 6000 miles. I changed them before to figure out the misfire. Now I pulled plugs out 3 and 4 and there was a brown ring around the porcelain. right where they connect to the metal part. Any ideas what could make them burn up there....
Old 01-11-2011, 03:22 PM
scotch89's Avatar
maybe injector but i rely dont see how that could affect it. does act wierd when your driving?
Dirty25RS's Avatar
What r u torquing them down to?
Is your valve cover leaking oil?
Are u using antiseize on the threads?
Old 01-11-2011, 03:28 PM
It drives fine I guess....all I have is a random misfire on 4 only....it def misfires because it turns my traction control off and my tranny shifts hard. I havent ran a compression test on it yet...gotta go fork out for a tester. not sure how to get it down into the spark plug hole down the valve cover.
I was told by a gm tech that the T/C turns off because of the misfire....no other codes though
DarrenGC
12-24-2021 01:55 PM
agentirons
10-16-2015 02:11 AM
tomj77
10-04-2015 11:39 AM
717ssbalt
10-02-2015 04:01 PM
anotherslowlnf
09-29-2015 03:52 PM
Quick Reply: What could cause my plugs to do this???
