What is the deal with my afr?
Old Jun 24, 2012 | 11:07 PM
06SS ALL DAY's Avatar
This only happens crushing from 5-50mph. At any speed between those two points crushing in any gear. Anything above 50 she's fine bouncing from 14.6-15.1. When it does do this I obviously let off and get back on than gas it to maintain speed and proper afrs. I also cleaned all sensors etc. changed air filter (non oiled filter). Still does it
http://www.youtube.com/watch?v=yX03uuhUoio&feature=youtube_gdata_player
Old Jun 24, 2012 | 11:18 PM
Edubs's Avatar
How long have you had the wideband and what do you have for a tune...
Old Jun 25, 2012 | 10:02 AM
06cobalt racer's Avatar
looks almost like "lean burn" it is a tactic to increase your fuel mileage while you are cruising. Chevy used to do it stock in the 90's. but then they stopped because doing this increases emissions.
i would talk to your tuner and see if that is what they are doing.
Old Jun 25, 2012 | 11:28 AM
ebristol's Avatar
Do you have a scan gauge to log your LTFTs and STFTs?
Old Jun 26, 2012 | 06:03 AM
No dice my tuner sold his hpt and moved onto a Evo. Also you can feel it pulling timing so it's def not that lean burning or whatever
Old Jun 28, 2012 | 05:59 AM
Old Jul 1, 2012 | 01:30 PM
Buuuump would it be my secondary o2? If so where can I get that part at?
Old Jul 1, 2012 | 01:33 PM
nhanson's Avatar
No it wouldnt. 2nd O2 is for making sure your cat is doing its job.
Old Jul 1, 2012 | 04:24 PM
I think I said it wrong. I am catless with a wideband. So would it be my upstream o2? (not on the dp)
Old Jul 1, 2012 | 04:50 PM
nhanson's Avatar
Mines weird too. If i let off but dont let DFCO kick in and then get into it, it will go lean then come back to normal.
Also car likes to randomly go lean when sitting at idle (wont happen if A/C is on)
Turbo Johnny
Feb 21, 2019 09:41 AM
TedSS
26
Oct 10, 2015 04:30 PM
footballplaya3k
Wheels and Tires
Oct 8, 2015 05:24 PM
Cptnslo
Sep 24, 2015 09:32 AM
