what the hell is this noise??
Old Jul 9, 2007 | 01:37 AM
2fastSS's Avatar
Ok so everytime i start my car up it has a squeking noise that like it sounds like a belt slipping but then when the car starts up it goes away after about 2 minutes....its from under the car as in somewhere on my exhaust
Old Jul 9, 2007 | 01:46 PM
Coblasts's Avatar
Sure its not the belt slipping a bit,If it isn't could be the down pipe moving on the manifold slightly when you start it and tightens up when it expands from the heat.
Front motor mount might have something wrong,(Excessive engine movment) take a look to make sure everything is okay
I wouldnt worry to much about it unless it gets worse
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Dylan Johnson
Sep 30, 2015 08:57 AM
