what are the symptoms of a bad motor mount?
Old Sep 12, 2012 | 12:17 AM
Shogokuma's Avatar
im trying to isolate a wobble in second gear
Old Sep 12, 2012 | 12:19 AM
turbosmart4's Avatar
Hmmmm maybe mine is bad too....
Old Sep 12, 2012 | 01:56 AM
Shogokuma's Avatar
i just installed a new powell racing trany mount and an lnf tranny mount (rear) still the same motor mount on top, front tranny mount was visibly dammaged (rubber)
Old Sep 12, 2012 | 02:36 AM
BankerBalt's Avatar
lots of jerking of the engine/tranny. i would suggest at least upgrading with ttr engine mount and tranny mounts if they're bad. best 250 bucks i've ever spent
Old Sep 12, 2012 | 02:46 AM
Stamina's Avatar
Does it wobble/stumble while cruising at constant speed? I had a problem with that and it ended up being unrelated to the mounts.
Old Sep 12, 2012 | 07:19 AM
TurboTechRacing's Avatar
Thanks for recommending our products.
Old Sep 12, 2012 | 02:14 PM
Shogokuma's Avatar
before i changed the mounts, i was experiencing a wobble in first gear low rpm accel. then i changed the front mount, the first gear has no woble but it seems like it shifted the wobble into second gear, and now that i have replaced the rear with an LNF, the wobble is only noticable on a hard launch when i get to second gear. as soon as i release the gas or disengage the clutch its smooth.
Oct 13, 2015 09:32 PM
ThoR294
Oct 4, 2015 08:44 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Stuff
Oct 1, 2015 05:47 PM
