Whats this sound? (Video)
Old Oct 8, 2014 | 05:51 PM
StevoElSupremo's Avatar
The car makes this weird howling sound as you get up to speed, not much<30Km/hr and its loudest at 80Km/hr then after that it sorta goes away(sorta)
If I throw the car side to side or hit the brakes it doesn't alter the sound in any way and I checked the tire on that side and nothing appears to be wrong with it
EDIT: went and jacked the car up and the wheel doesn't appear to have play, I dont get it
Anyways here's the clip, its that feint howling/whiring sound you here sorta fadking in and out and changing sound through the clip but its louder in person, right around 10 and 20ish seconds its pretty pronounced
Old Oct 8, 2014 | 06:01 PM
LNFTX's Avatar
Does it change with rpm or speed
Could it be a faint exhust leak?
Had to have my exhuast fixed road debris put a small hole in it. I finaly figured out what it was getting under it while idling
Old Oct 8, 2014 | 06:06 PM
nathan112i's Avatar
sounds like you have 38inch mud tires on! have you tried jacking the car up and seeing if there is any slop in the wheel bearings?
Old Oct 8, 2014 | 06:38 PM
For sure not exhaust
It changes with speed, Just went outside now that I had a second and jacked that side up and the wheel doesn't appear to have play, like I've seen a wheel with a bad bearing and it jiggled side to side and made a clunking sound, mine doesn't do that
Well I looked on youtube and they said if you spin the wheel and feel the spring vibrating its the wheel bearing, I spun the problem side and I felt an EXTREMELY feint vibration and the other side I felt nothing on the spring, so can I assume its a wheel bearing?
Old Oct 8, 2014 | 10:27 PM
nathan112i's Avatar
judging by the sound of the video thats what i would be looking at first. you can try going like 80km/h and turning the car left or right to see if the noise becomes more faint. they wont always have slop in them sometimes the bearing race become pitted and make a hell of a racket.
Old Oct 8, 2014 | 10:34 PM
I'm thinking a wheel bearing as well
Old Oct 9, 2014 | 05:57 PM
Yeah ok I'm going to change it this weekend (only time I have time lol) its gotten louder today, same type of airplane sound but much louder and god damned annoying.
Old Oct 12, 2014 | 08:48 AM
Bump for anyone else' future use, Yes it was the wheel bearing, changed it yesterday and no more airplane noises
oh and as an FYI, the How to said the axle nut was a 30mm, but mine was 35mm
Old Oct 12, 2014 | 12:20 PM
nathan112i's Avatar
good to hear it was something simple! did you tear the bearing apart and inspect the carnage?
Old Oct 12, 2014 | 03:23 PM
lol no I haven't... but now I want to.. hmm I might have to, I did bang the studs out to keep though, I might go take the bearing apart, if I do I'll post pics
Old Oct 12, 2014 | 03:25 PM
chris88z24's Avatar
A wheel bearing has to be completely fucked if there is any play in it. The best way to check for a bad wheel bearing is to take the wheel off and spin the hub by hand. A bad bearing will feel gritty.
Old Oct 12, 2014 | 03:52 PM
yeah it does feel gritty, it happend so suddenly, the car was driving fine then a humm started out of no where and just got so damn loud lol
Old Oct 12, 2014 | 04:37 PM
nathan112i's Avatar
in for pics!
Old Oct 12, 2014 | 08:38 PM
chris88z24's Avatar
I had two go bad at the same time. The car sounded like a Cessna going down the road. lol
Old Oct 13, 2014 | 11:00 PM
Solitaire514's Avatar
What brand bearing did you replace it with?
Old Oct 13, 2014 | 11:23 PM
Sl0wbaltSS's Avatar
Sounds like straight cut gears :p
Old Nov 17, 2014 | 08:25 PM
Sooooo.. that damn sound is back, it was gone up until now but it's creeping back and getting louder, quest que ****.
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
