wheel bearing specs
Old Apr 19, 2012 | 11:47 PM
YesYestotheSS's Avatar
Exclamation wheel bearing specs
can some one please gimme the stock wheel bearing specs.
i tried replacing my front hub assemply with a timken HA590086 and it didnt fit on the axle. the hole for the axle in the new hub assembly was smaller than the one i had on my car.
any thoughts? im pretty sure i dont have aftermarket axles.
Old Apr 19, 2012 | 11:49 PM
ItalianJoe1's Avatar
You probably got LSJ hubs.
Old Apr 20, 2012 | 03:26 PM
i might have, there was no part number on the actual part for me to tell.
would you happen to know the diameter of the hole for the axle to fit through would be on LNF hubs?
every site ive looked at says its 1.53 or 1.54 but for me i need another quarter inch maybe.
Old Apr 20, 2012 | 07:29 PM
Coblasts's Avatar
Lsj has 5 lugs does the plain SS have 5 or 4 haven't really paid attention to that detail ?
Old Apr 20, 2012 | 09:25 PM
All "SS" models have 5 lug hubs. Some high-level LT models also had 5 lug and 4 wheel disc brakes.
Old Apr 21, 2012 | 03:57 PM
SS have five lugs
the diameter for the hole for the axle to go into is what i need to find out for our stock ss/tc setup
i need a new bearing. i should like an airplane -___-
Old Apr 21, 2012 | 05:16 PM
Powell Race Parts's Avatar
u need an LNF hub. u got the wrong hub.
Old Apr 21, 2012 | 06:02 PM
so the timken HA590086 is the right part number ? (for this brand)
do you know of any other part numbers i could possibly look into?
Old Apr 21, 2012 | 07:16 PM
gotta say this is frustrating, I try to help folks but try the search button on the web: google goes a long way and amazon has some good deals. here is the listing for 2010 turbo cobalts off rock auto, i prefer to shop at crate engine depot, but here you go:
ACDELCO Part # RW2080 More Info {#15839051, 22671548} Wheel Race; replaces 22671548
BEARING,RR WHL w/SOFT RIDE SUSP(FE1) or CAST IRON FRT DISC/RR DRUM BRK SYS(J41); INCLS HUB
CAD$113.91
ACDELCO Part # FW344 More Info {#22701520} Wheel Race
BEARING,FRT WHL w/CAST IRON FRT DISC/RR DRUM BRK SYS(J41)
CAD$142.68
ACDELCO Part # RW20108 More Info {#15798483, RW2079} Wheel Race
BEARING,RR WHL w/PERF & HANDLING SUSP(FE5) or FRT & RR DISC ANTILOCK BRK(JL9); LH AND RH
CAD$172.45
ACDELCO Part # FW301 More Info {#15793213} Wheel Race
BEARING,FRT WHL w/FRT & RR DISC ANTILOCK BRK(JL9)
BEARING,FRT WHL w/ACTIVE BRAKE CONTROL(JL4)
CAD$174.44
note here that the listing includes disc drum cars so does not belong in this listing for turbo charged cars, so the last two for disc disc turbo cobalts are the only bearings rear and front that apply.
all turbos sedan (09 only irrc) and coupe 2008-10 are the same for bearings.
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
DANRICKARD
Oct 1, 2015 12:08 AM
