Whirring/Whining Noise
Old May 19, 2014 | 09:41 PM
Synergy1415P3's Avatar
Hello All,
I have had this issue all winter but did not realize it until I put my summer tires on as I thought it was just loud winter tires. It sounds like I have mud tires on. Any ideas? Wheel bearing?
Thanks
Old May 21, 2014 | 12:32 AM
Old May 21, 2014 | 02:50 AM
Acer00789's Avatar
More info would help: Does the sound exist while stoped or while in motion? Does the sound change in pitch or intensity depending on speed, RPM, or turning?
Old May 21, 2014 | 08:26 AM
05g5's Avatar
wheel bearings. mine went out at 180k and 210k kms. sounds like a semi on the highway. you will be amazed at how quiet the ride is when that humming/rumbling is gone.
jack car up, take tires off and turn each side by hand, i could feel the bad bearing both times no problem.
Old May 21, 2014 | 09:45 AM
Doesn't happen while stopped, only in motion. Intensifies at higher speed.
Think so?
Old May 21, 2014 | 09:48 AM
RyBread761's Avatar
If you can turn at speed and it goes away when turning in one direction only, this could also be an indication of a bad bearing. Or it could be a CV joint. Does it change sound when you hit bumps?
Old May 21, 2014 | 09:50 AM
Haven't really hit any big bumps.
Old May 21, 2014 | 09:53 AM
RyBread761's Avatar
It also occurs on dips in the road or anything that would change the angle of the shaft while being driven. Odds are if you haven't noticed it made changes in sound already, it probably is just a bearing.
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
