Whistling Noise WOT
Old Aug 2, 2008 | 04:20 AM
CobaltTSX's Avatar
Whistling Noise WOT
I have heard a whislting noise at WOT in the upper RPM range. Almost sounds like a loose vac line but all lines are tight no cracks no nothing. Just wondering if anybody else has heard this on their balts Oh yeah by the way 2.2 auto.
Old Aug 2, 2008 | 04:25 AM
chillfactor's Avatar
do you have an aftermarket intake
if so its cuz of that mine does the same thing but only arounf 3-4 k
Old Aug 2, 2008 | 04:26 AM
CobaltTSX's Avatar
No everything is stock at the present moment.
Old Aug 2, 2008 | 04:31 AM
hum im not to sure could honestly still be the intake i think my friend coablt which is stock does the same i know mine gets louder also if the ac is on lol
Old Aug 2, 2008 | 08:26 AM
DarkSergeant's Avatar
IF you have a a garage or other enclosed area where you'd feel comfortable doing so, you could try removing the air intake and seeing if the whistle persists.
I'm guessing you've tried having someone else rev the car while you stand over the engine to see if you can determine it's location or does it only happen while DRIVING at WOT?
Could also be this...
http://www.youtube.com/watch?v=ccgXj...eature=related
Old Aug 2, 2008 | 11:27 AM
CobaltTSX's Avatar
Ha Ha no its not a whistle tip. Yes I've listened outside the car and it doesn't do it. It seems to be only when under a load.
Old Aug 2, 2008 | 11:50 AM
116Fanatic's Avatar
Could be an exhaust leak?
Old Aug 3, 2008 | 06:31 PM
Jeremy360's Avatar
"Yeeeah I got it on my car" that's a hell of a way to get it keyed.
On-topic though, my cousin's 2.4 had a whistle with the stock airbox. I couldn't diagnose it, but after pulling it and replacing it, it disappeared. He's since gone to a K&N intake and it came back with a loose clamp. Only at WOT seems strange though, you should be able to hear it before then.
Old Aug 3, 2008 | 10:07 PM
Preowner's Avatar
There have been alot of issues caused by dirty throttle bodies on the cobalts it seems. Might aswell clean it out for the hell of it
Old Aug 3, 2008 | 10:20 PM
theneelster's Avatar
Whistling from your exhaust points to a bad cat. Dealer time.
that only fixes idle and code issues.
Last edited by theneelster; Aug 3, 2008 at 10:20 PM. Reason: Automerged Doublepost
Old Aug 4, 2008 | 12:00 AM
CobaltTSX's Avatar
Well if its the exhaust or the cat the dealer can't do much for me. My warranty went out the window a while ago. The only thing I have left is the power train warranty cuz as of yesterday my balt has 48,000 miles on her. I did notice the one time I took the air intake off to take measurements to make my own and put the stock one back on it went away for like an hour or two. Maybe I'll just tighten the heck out of the clamps and see what happens.
Old Aug 4, 2008 | 12:06 AM
rukkee's Avatar
If it's the cat thats bad they will cover it , it's warrantied for like 8/80K miles IIRC
Old Aug 4, 2008 | 12:12 AM
FASTL61's Avatar
when i had stock intake it did the same but there is only one vac line and its for the booster.any way like i said mine did the same and a couple other guys i know as well
Old Aug 4, 2008 | 12:18 AM
originaladrian's Avatar
its normal trust me mine does the same thing before shifting when the pedal is released
Sl0wbaltSS
Nov 21, 2018 11:11 PM
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
