White smoke =bad???
Old Sep 30, 2007 | 11:56 PM
BallsoutBalt's Avatar
White smoke =bad???
Hey guys,
I got white smoke coming out of my tailpipe, and my oil catch can filter is smoking really bad.
First one to tell me what is wrong and the solution gets a rep point. *shrug* sorry but thats the best I can do.
Seriously though, anyone?
Old Sep 30, 2007 | 11:59 PM
nramlow2006's Avatar
if i remember correctly.. white is overheating black is burning oil...
Old Oct 1, 2007 | 12:00 AM
sick06cobalt's Avatar
^^ is correct.. black is oil...
when is the last time you check your fluid levels..
check your coolant level and see what your running at...
fballman1987's Avatar
i always thought white was headgasket.. black is burning oil, could be wrong though...
Old Oct 1, 2007 | 12:01 AM
you might be low on oil.. witch is causing you to over heat... just a though..
Originally Posted by stripedHEMI766
chances are a blown headgasket, check your coolant, better yet, drain you coolant and start the car, if you have exaust gas coming out, its blown
he would know he is a certified tec..
Last edited by nramlow2006; Oct 1, 2007 at 12:01 AM. Reason: Automerged Doublepost
Old Oct 1, 2007 | 12:04 AM
You guys are awesome! I'll check the coolant level and see if there is any nasty **** in there, Oil is good though.
That is kinda what I was thinking. =(
Last edited by BallsoutBalt; Oct 1, 2007 at 12:04 AM. Reason: Automerged Doublepost
Old Oct 1, 2007 | 12:07 AM
ItalianJoe1's Avatar
White smoke out the back, is it smoke or steam? Burning coolant usually is more like steam, where oil is smoke. If you are seeing stuff in the catch-can as well, i'd vote for maybe a cracked ring or something. Is the idle smooth and normal?
Old Oct 1, 2007 | 12:22 AM
Novajoe's Avatar
white smoke means you're burning coolant. Whether it's coming in through your headgasket or on these cars it could be coming through the intake from your supercharger cooling system. Do a compression test. If compression's good on all cylinders then it's coming through the intake.
Old Oct 1, 2007 | 12:24 AM
2.4SlowassBalt's Avatar
wow erbody beat me 2 it
Old Oct 1, 2007 | 01:17 AM
wmdm's Avatar
White smoke (actually steam) = coolant getting into cylinder.
Blueish white smoke = Oil in cylinder! It can range from smoking only when the engine is first started and then going away as it warms up to blowing so much damn smoke the people behind you have a hard time seeing where they are going.
Black smoke = excess fuel, running way to rich.
If it is white smoke from coolant, it will be like when you first start your car in extremely cold weather. It will come out real thick but dissipate so that you do not see a long trail of smoke rising up into the sky. It will seem to disappear like steam.
Blueish white smoke from oil does not dissipate quickly or go away quickly like steam.
Here is a good link;
http://www.trustmymechanic.com/troubleshoot_smoke.htm
And when they say blue smoke it is actually a very light blue white tint to the smoke.
Old Oct 1, 2007 | 10:45 AM
Well it is a constant smoke that does not go away. My girl was folowing me on Saturday and she said a bigger cloud would come out when I shifted. If I sit at a light it is a canstant flow.
I am getting a Leak-down test done tomorrow. I really hope it's nothing too bad. I'll let you guys know what happens.
Old Oct 1, 2007 | 10:49 AM
SSCobalt~SSZ24's Avatar
white smoke = coolant in the oil sux
Old Oct 1, 2007 | 11:21 AM
Possible solution??????
Old Oct 1, 2007 | 11:24 AM
07cobaltss's Avatar
well how "bad" is it. because some smoke is normal, but if you pouring it out like a mosquito fogger, then i'd say head gasket, or a coolant leak somewhere.
not always, look at the dipstick, does it look like chocolate milk? if so then yeah that=bad news. i really dout that though becuase it still wouldnt get past the oil rings,and if it did then you would burn. BLUE smoke, blue smoke= oil, white= coolant, black= rich
Old Oct 1, 2007 | 11:26 AM
Shifting gears under normal conditions puts out a good smoke screen. Idling at a light makes other folks roll up their windows.
It is not a "normal" amount at all.
The smoke coming out of the oil catch-can filter is the worst. You can actually see how the oil was blown out the top of it.
Old Oct 1, 2007 | 11:27 AM
That sounds like oil sucking past a valve seal or something similar. I had a Tercel that used to do that, it was common on those cars. Check your oil level, and look around your exhaust tip, you might even have oil spots if its bad enough.
I checked the dip stick on saturday, looked normal.
Old Oct 1, 2007 | 11:29 AM
I would bet its something in the head, either a cracked valve seat or bad valve seal, something allowing CC pressure to blow out the oil and suck it down into the cyl's under high vacuum conditions like idle and shifting.
So i know that we have all the POSSIBLE things it could be and I wont know exactaly what it is till tomorrow, but with what we have all discussed, what am I looking at part-wise to fix this?
Old Oct 1, 2007 | 11:31 AM
Depends on what broke. Could be any number of things, but you are looking at a pretty good tear-down of the engine, so get ready for a big bill.
Old Oct 1, 2007 | 11:34 AM
07cobaltss's Avatar
now this smoke is coming out of the tail pipe right?
Old Oct 1, 2007 | 11:39 AM
Tail pipe and the oil breather on the catch-can.
LOL, ya I figured it is going to be a couple thousand in parts, but I need to start ordering stuff ASAP.
Last edited by BallsoutBalt; Oct 1, 2007 at 11:39 AM. Reason: Automerged Doublepost
Old Oct 1, 2007 | 11:40 AM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
blown head gasket FTW
