White smoke =bad???
Well lets assume it's only the head gasket... Would it be logical to get pistons, rods, valves, etc... while I have the engine open? Understand I am not made of money (I bbarley make 30 K a year) and I'll have to take out a personal loan just to fix the headgasket, but should I get a bigger loan and throw money at the stuff that could go wrong? I like to do things right the first time.
Thoughts???
Thoughts???
if it's a headgasket then get a head gasket kit. You won't need to replace pistons, rods, etc. But you should replace the valve seals, valve cover gasket, have the head resurfaced(if it's warped at all), change your thermostat and flush your coolant, change your oil and filter. Basically change out all the gaskets and seals on the head.
But DO A COMPRESSION TEST FIRST. Make sure it's the headgasket. It could be coolant from your s/c cooling system also.
No it hasn't
Last edited by BallsoutBalt; Oct 1, 2007 at 04:14 PM. Reason: Automerged Doublepost
Well realisticaly, can you really tell the diff between white and blue smoke. I mean I have seen them both but its always hard to tell them apart. Maybe I'm just color blind *shrug*
we'll call it "bluish-white" Either way the Leak-down test is getting done tomorrow so that will tell me exactally what is going on. RIGHT?
Last time I had white smoke pour out of an exhaust it was because there was too much oil
in the car and it blew oil passed the rings and on top of the pistons.
Problem was solved with a little blood-letting
-edit: As a side note, the poor fella I was racing at the time thought someone threw a
sheet over his windshield
Manual says 5.5 qts.
Last time I had mine in for one it took 6 to fill it properly.
If the folks you had doing yours accidentally over-filled it then that
would be my bet. (The car I over -filled was a VW Jetta)
Just heard from the mechanic. He said the piston rings are done, and the cylinder walls will most liklet be damaged.
Not what I wanted to hear, but I was expecting something similar.
Any suggestions guys?
Last edited by BallsoutBalt; Oct 3, 2007 at 03:51 PM. Reason: Automerged Doublepost
high hp engine build?
What injectors did you have again?
