Why is my boost so high?
Old Feb 10, 2014 | 08:33 PM
Slednecks96's Avatar
I have an 05 SS S/C. When I got it like 2 months back the guy told me it had a gm performance exhaust and K&N typhoon intake. When I looked through the stack of receipts I found out there was more to it. Stage two computer, stage two pulleys, 2 pass inter cooler end plate, thicker cv axles, and found a folder with papers for LSJ upgrade stage 3 and stage 3 PCM. I noticed cut wires on PCM though. Also found Dyno sheets that said stage 3 cobalt. Said 230 hp and 176.3 torque. I'm just frustrated because I have no idea what is actually done to it. I'm not very familiar with these cars. I know it has the 2 pass from the dual reservoirs though. I didn't really beat it till the other day. Looked like it was running 15 psi but when I really got on it it climbed all the way to 20 psi. I don't know if the gauge is off or? What do you guys think? I just don't want to over boost and blow it up.
Old Feb 10, 2014 | 08:37 PM
TStone's Avatar
Post some pics of the engine bay, the injectors, the pulley, and said cut wires.
Old Feb 10, 2014 | 08:47 PM
Whitnith's Avatar
The dual pass isn't having two coolant tanks.
Two coolant tanks is something called the Option B setup.
The dual pass is something you can't really see just by looking at the car, it's the endplate to the intake manifold.
That dyno sounds very low, being a Stage 3 and only 230, so that's weird.
Old Feb 10, 2014 | 08:50 PM
Old Feb 10, 2014 | 08:51 PM
Last edited by Slednecks96; Feb 10, 2014 at 08:51 PM. Reason: Automerged Doublepost
Old Feb 10, 2014 | 08:54 PM
Here's the car just made a photobucket for this thread haven't posted a pic of my car on here yet Name:  image_zpsab6c1a61.jpg
Old Feb 10, 2014 | 08:56 PM
SunburstSS's Avatar
Boost going up that high when you step on it means a clogged cat converter, if it is stock there is an extended recall on them upto 120k or 10 years I believe.
Old Feb 10, 2014 | 08:58 PM
Wouldn't it throw a code for bad efficiency?
Old Feb 10, 2014 | 09:17 PM
ItalianJoe1's Avatar
Get us a pic of the S/C pulley or read the size off of it if you can.
Old Feb 10, 2014 | 09:23 PM
Looked like it said 76.00 mm Name:  image_zpsfbfec1f0.jpg
Old Feb 10, 2014 | 09:27 PM
umrdyldo's Avatar
Clogged cat vote
Old Feb 10, 2014 | 09:30 PM
No code though? ^
Old Feb 10, 2014 | 09:45 PM
SunburstSS's Avatar
Originally Posted by Slednecks96
No code though? ^
No code needed lol....Had the same issue too back in the day, you step on it and poof the gauge maxes out....
Old Feb 10, 2014 | 09:48 PM
Powell Race Parts's Avatar
^^^ this
Old Feb 10, 2014 | 09:50 PM
Damn has 145k lol
Old Feb 10, 2014 | 10:01 PM
TurboTechRacing's Avatar
Ding ding!!! Winner winner!!!
Old Feb 10, 2014 | 10:51 PM
Ryan40oz's Avatar
my stock boost was hitting 17 psi at once point after 3-4 times opening her up , my cat light came on, needless to say i put a free flow in after now its back down to the stock 13 psi its supposed to push
Old Feb 10, 2014 | 11:53 PM
Yeah man. Just sucks been nothing but problems so far. Need to do water pump, axle seals and possibly cat now. Breaking the bank! Haha
Old Feb 11, 2014 | 07:26 AM
Staged07SS's Avatar
Administrator
Administrator
That's a gmr s3 pulley.
I'm a full gmr s3 car and have never seen boost levels anywhere near that.
Clogged cat, and colder temps are the factor for sure.
Those look like the gmr s3 nitrous jumper wires, but they arent hooked up to the PCM (OBVI).
A gmr s3 car with the M62 and full exhaust will be closer to 250whp while running 93 octane.
The 230hp 176tq dyno could have been a stock pull.
Old Feb 11, 2014 | 07:34 AM
blueLNFftw's Avatar
Or if it was recent the cat could already have been clogged up some
Old Feb 11, 2014 | 07:40 AM
Staged07SS's Avatar
Administrator
Administrator
could have...
Old Feb 11, 2014 | 07:50 AM
blueLNFftw's Avatar
could have...
Its that boost addition mod yo
Old Feb 11, 2014 | 07:53 AM
Staged07SS's Avatar
Administrator
Administrator
Old Feb 11, 2014 | 08:32 AM
ranviper's Avatar
Sounds like your previous owner beat on it pretty good, already having so many problems. Another vote for the clogged cat though.
Old Feb 11, 2014 | 08:39 AM
blueLNFftw's Avatar
already? It has 145k...
