winshield wipers dont stop
So here is the problem...my windshield wipers dont stop, i have to turn the car off and pull the fuse or relay to make them stop. Also I have no control over the speed, just constant movement, no delay. At least they don't turn on automatically, they just don't stop.
I checked the fuses and relays and they all look good, I tried swapping relays, no change.
Thanks
Thanks
If its staying on in slow speed it could be wpr 1 relay stuck on by the looks of the print.
Do they keep running even if you pull wpr1 relay ?
Can you adjust speeds even though ignition is off and key removed?
Just try tapping on the wpr relays to stop the wipers ,if that works it is the relay.
Could also be a problem with the bcm.You havent wired anything into that circut have you ?
i have no control over speed...same speed all the time, forever...until I pull the relay/fuse. I'm not sure what relay I pulled, its the one closest to the fuse though. I would pull the fuse, but its hard to time it so they stop in the down position with the fuse. Moving, tapping, hitting the relays has no effect. I think that my radar detector is hardwired into the ignition wire (brown) in that area. I also have a "add a fuse" in the sunroof fuse (no sunroof on car).
1 Did you perform the Diagnostic System Check - Vehicle?
Yes -Go to Step 2
No -Go to Diagnostic System Check - Vehicle
2 Turn the ignition ON.
Turn the windshield wiper/washer switch OFF.
Do the windshield wipers remain in the PARK position?
Yes - Go to Testing for Intermittent Conditions and Poor Connections
No - Go to Step 3
3 Disconnect the harness connector of the windshield wiper/washer switch.
Do the windshield wipers stop?
Yes -Go to Step 11
No -Go to Step 4
4 Connect a test lamp from the signal circuit of the windshield wiper/washer switch at the body control module (BCM) to a good ground.
Does the test lamp illuminate?
Yes -Go to Step 9
No -Go to Step 5
5 Connect a test lamp from the supply voltage circuit of the wiper 2 relay coil to a good ground.
Yes -Go to Step 14
No -Go to Step 6
6 Connect a test lamp from the control circuit of the windshield washer pump to a good ground.
Yes -Go to Step 15
No -Go to Step 7
7 Disconnect the wiper 1 relay.
Yes -Go to Step 8
No -Go to Step 16
8 Connect a test lamp from the supply voltage circuit of the wiper 1 relay coil to a good ground.
Yes -Go to Step 10
No -Go to Step 12
9 Test the signal circuit of the windshield wiper switch for a short to voltage. Refer to Circuit Testing and Wiring Repairs .
Did you find and correct the condition?
Yes -Go to Step 20
No -Go to Step 13
10 Test the supply voltage circuit of the wiper 1 relay for a short to voltage. Refer to Circuit Testing and Wiring Repairs .
Yes -Go to Step 20
No -Go to Step 13
11 Inspect for poor connections at the windshield wiper/washer switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Yes -Go to Step 20
No -Go to Step 17
12 Inspect for poor connections at the wiper 1 relay. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Yes -Go to Step 20
No -Go to Step 18
13 Inspect for poor connections at the BCM. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Yes -Go to Step 20
No -Go to Step 19
14 Repair a short to voltage on supply voltage circuit of the wiper 2 relay coil. Refer to Circuit Testing and Wiring Repairs .
Did you complete the repair?
Yes -Go to Step 20
No - --
15 Repair a short to voltage on control circuit of the windshield washer pump. Refer to Circuit Testing and Wiring Repairs .
Yes -Go to Step 20
No - --
16 Repair a short to voltage on high speed circuit of the windshield wiper motor. Refer to Circuit Testing and Wiring Repairs .
Yes -Go to Step 20
No - --
17 Replace the windshield wiper/washer switch. Refer to Windshield Wiper and Washer Switch Replacement .
Did you complete the replacement?
Yes -Go to Step 20
No - --
18 Replace the wiper 1 relay.
Yes -Go to Step 20
No - --
19 Replace the BCM. Refer to Control Module References for replacement, setup, and programming.
Yes -Go to Step 20
No - --
20 Operate the system in order to verify the repair.
Did you correct the condition?
Yes -System OK
No -Go to Step 3
Yes -Go to Step 2
No - Go to Step 3
Yes -Go to Step 11
No -Go to Step 4
Yes -Go to Step 9
No -Go to Step 5
Yes -Go to Step 14
No -Go to Step 6
Yes -Go to Step 15
No -Go to Step 7
Yes -Go to Step 8
No -Go to Step 16
Yes -Go to Step 10
No -Go to Step 12
Yes -Go to Step 20
No -Go to Step 13
Yes -Go to Step 20
No -Go to Step 13
Yes -Go to Step 20
No -Go to Step 17
Yes -Go to Step 20
No -Go to Step 18
Yes -Go to Step 20
No -Go to Step 19
Yes -Go to Step 20
No - --
Yes -Go to Step 20
No - --
Yes -Go to Step 20
No - --
Yes -Go to Step 20
No - --
Yes -Go to Step 20
No - --
Yes -Go to Step 20
No - --
Yes -System OK
No -Go to Step 3
I didn't have a chance to go over the troubleshooting procedures last night but, I just noticed something on the way in to work this morning, when my wipers are on the light for the rear window defogger is also on. I can't make the light go out, but when the wipers are off the light functions normally. Im fairly certain that the two issues are related. Now I just need to wait till I get home and find out where these signals cross.
Un install the radar detector first and see if that makes any difference.
Try wiggling the wires on the steering colum to see if you can get the wipers to stop(possible short to voltage)
