Wiper relay causing major engine misfires
Old Jun 11, 2012 | 06:26 PM
antieatingactivist's Avatar
Hi everyone. I was hoping to get a little insight on a problem that I have never come across before. A friend of mine has an 07 cobalt LS. The CEL came on one day, so we scanned it. It came up with a lean code and and a misfire code. All of a sudden it started shifting hard and hesitating a little. I put in new plugs and front O2 sensor, since the car was at 100,000 miles. I also checked the fuel pressure, which seemed fine. Eventually it got so bad that it would barely run. I suspected water in the fuel (his gas cap was broken and fell off when I opened the gas door), so I drained the tank and put new gas, then I swapped the injectors from a totaled car at my work. Here's the weird part...
I accidentally hit the wiper switch. wipers turn on, but won't turn off, even when I turn the key off. They also go at the same speed no matter which setting. To get them to stop I pulled the relay. When I did this the engine revved up briefly and started running perfectly. When I plug the relay back in, engine sounds like its running on 2 cylinders.
Does anybody have a clue to what could be going on here? I really do appreciate any suggestions. This car is much different than my 1987 diesel mercedes. Thanks in advance.
Old Jun 11, 2012 | 06:43 PM
LS6Rally's Avatar
sounds to me like a fried Computer somewhere. hopefully someone else can chime in with a better answer
Old Jun 11, 2012 | 07:14 PM
Thanks for the reply. Computers in cars are mysterious. You would think they would either work, or not work at all.
ernnyyes
Oct 2, 2015 05:16 PM
717ssbalt
Oct 2, 2015 04:01 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
