Won't start. Not turning over
Old May 13, 2013 | 01:13 PM
toysareforboys's Avatar
Originally Posted by Dfields
That is correct if it was hydra lock the starter would make some kind of noise I have replaced the starter and checked out the clutch switch now onto the ignition
If it works if you bump start it, why not run a new wire right to the starter relay, to a push button inside the car! Turn the key to on, "push to start", sweeeeeeet.
-Jamie M.
Old May 13, 2013 | 07:32 PM
Psykostevo's Avatar
What about the starter solenoid? Not sure what the starter setup is like on the cobalt.
Old May 13, 2013 | 10:09 PM
Dfields's Avatar
When replacing the starter it came with a new solenoid the people at auto zone did tell me my starter failed the test so I replaced it...looking into an ignition switch and tumbler...
Old May 14, 2013 | 03:42 PM
Psykostevo's Avatar
I hate throwing parts at problems. I feel for you man.
Old May 14, 2013 | 04:11 PM
Dfields's Avatar
Exactly what I'm doing but other than the ignition im running outta ideas... I can't throw anymore money at it if I have absolutely no idea where else to throw it at
Old May 14, 2013 | 09:46 PM
Dfields's Avatar
Ok so after scratching my head for a few days I jumped back into it I took the supercharger back off as well as the intake so I'm back down to nothing...is their anyone that can think of anything I could do to possibly gett it running any hidden grounds could be cleaned anything I should test??? And one question the wire on top of the starter the bigger of the two posts has two wires connected to it one goes to the positive on the underhood fuse box the other to the stud on the alternator??? Thanks for your help guys
Old Jun 5, 2013 | 07:13 PM
GTOworshiper9's Avatar
Bringing this thread back.
I'm having this exact same problem after disconnecting my battery. 98% sure it's the anti-theft because after establishing comm with the bcm its saying its in learn mode for the key re-learn and even recognizes my key as not learned but the gm re-learn procedures aren't working.
I'll let everybody know what I find
Old Jun 7, 2013 | 03:05 PM
Dfields's Avatar
well i figured mine out... thanks for all the thoughts guys but I'm kicking myself in the ass this time lol... SHE RUNS AND STARTS yayyyyyy
Old Jun 7, 2013 | 03:10 PM
Sox-Fan's Avatar
Got Brakes?
and the issue was?
Old Jun 7, 2013 | 03:14 PM
Dfields's Avatar
the crank fuse.... i checked all the fuses once and dint find one bad one...it was the second time i went through everything i found it... it isn't a normal fuse its a weird tall one which explains how i passed right over it...such a ******* thanks though for everything and she ended up with a new battery and starter oh well lol
Old Jun 7, 2013 | 03:17 PM
  #36
Sox-Fan's Avatar
Got Brakes?
Thanks for letting us know. It might help the next guy.
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
roth
Sep 26, 2015 12:16 PM
