wow sound from engine
Old Dec 8, 2009 | 12:27 AM
blacksssc05's Avatar
well i started up my ss just a few mins ago and its has the timing chain knock and when the thottle is let off it sounds like a whole bunch of metal is hittin the top of the vavle cover...does my chain and tensioner have to be replaced? or is it a blown engine... the sound is on the passenger side of the car...and no metal flakes in the oil
Old Dec 8, 2009 | 12:29 AM
constantproject's Avatar
replace your chain and tensioner and guides...or you will need a new valve train soon too
Old Dec 8, 2009 | 12:36 AM
where do i get a new vavle train and how much does that cost?
Old Dec 8, 2009 | 12:50 AM
valvetrain= expensive, timing chain+tensioners+guides=less expensive
if you wait till it goes alltogether=even more expensive
Old Dec 8, 2009 | 12:53 AM
so i should probably the car towed in for service....bout 600 to have it all fixed prolly right?
Old Dec 8, 2009 | 01:13 AM
i dont know about towed, if its driveable you should be ok, let it warm up and take it easy on your way to a mechanic, wheather thats your dealership or not is your choice,but if your mostly stock you might consider trying to get it warranty'd. either way you should get it looked at as soon as possible if it sounds that bad...i know my car has a weird lifter tick but it hasnt gotten any louder or changed at all so i listen to it when i start it and pay attention to it in case it does.you shoul;d do the same after you get the problem resolved.
i would take it in and tell the dealership about what is happening and see what they say, it might be a simple adjustment that they have a service bulletin about. but there is also the chance that it is serious . if you go upgraded top end it gets expensive so if your not going to do any serious modifying its not really worth it imho. good luck keep us posted
oh and dont let the dealership tell you that because you have a cold air intake and a exhaust that your warrany is void...you only void your warranty if what you have done IS THE CAUSE OF THE PROBLEM!!
Last edited by constantproject; Dec 8, 2009 at 01:13 AM. Reason: Automerged Doublepost
Old Dec 8, 2009 | 09:24 AM
its the chain and the tensioner...i have a guy fixin it this weekend...10 miles should be ok right?
Old Dec 8, 2009 | 05:17 PM
bump...
Old Dec 9, 2009 | 08:27 AM
cool everyone is such a BIG help here!!
Old Dec 9, 2009 | 09:30 AM
383_Stroker's Avatar
Putting a tensioner in is a 20 minute job.. Replacing the chain is full afternoon... your chain is probably fine if you've not gone very far with it rattling.. I'd try changing the tensioner only
Old Dec 15, 2009 | 09:01 AM
sorry bro been busy and out of town, how did everything go?
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
