WTF... why when i get gas wont my car start till....
Old Oct 27, 2009 | 10:36 PM
Gestapo007's Avatar
Last time I put gas in my car (93 octane), immediatly after filling i went to start my car and it wouldnt crank. Took 3 times to start my car and I got all scared, but thought it was a fluke and since everything ran fine since, no starting problems after. Then tonight, I fill up my tank, and once again, immediatly after filling takes 3 cranks for it to start.
Never happened in the past, so WTF?
Old Oct 27, 2009 | 10:40 PM
BLAZIN07SS's Avatar
I'm too JDM for you
no crank at all?
Old Oct 27, 2009 | 10:43 PM
damien's Avatar
I read about this like 2 weeks ago. **** I can't remember **** about it though!
Gestapo007's Avatar
the engine will turn but it wont ignite ya know. so it will crank just wont start up
Old Oct 27, 2009 | 10:45 PM
BLAZIN07SS's Avatar
I'm too JDM for you
EVAP issue
Old Oct 27, 2009 | 10:47 PM
Gestapo007's Avatar
...what does that mean lol
Unforgiv3n's Avatar
EVAP issue
Yup, on my car the evap purge valve was stuck open.
Old Oct 27, 2009 | 10:48 PM
Gestapo007's Avatar
so how do i fix that
Old Oct 28, 2009 | 12:13 AM
LTZ XsTaT1c's Avatar
get out of the car n kick it 3x and it should start up......but seriously could it have something to do with your new fuel pump???
Old Oct 28, 2009 | 12:24 AM
nybull05's Avatar
the evap is either the gas cap or theres a evap purge valve under the car. back by the rear frame. might need to be replaced. but try the gas cap first. do you get a check engine light?
Old Oct 28, 2009 | 12:27 AM
BLAZIN07SS's Avatar
I'm too JDM for you
btw when you fill up your gas do you stop as soon as it clicks or do you try to shove that extra $2 in there. lol
Old Oct 28, 2009 | 12:39 AM
JsavageSS/TC's Avatar
definalty EVAP.... mine did that and the stealership had to replace the EVAP Canister twice.... they tried to blame it on me by telling me I was over filling it, but I always stop when it clicks....
Old Oct 28, 2009 | 12:51 AM
rcorona8's Avatar
Same problem here for the 6 months. can somebody pin point exacly where this EVAP is in the SC Model so i can be able to replace it ? thanks
Old Oct 28, 2009 | 06:54 AM
Gestapo007's Avatar
i dont know if I got a CEL b/c it was already on since my catless DP. but im not gonna say there wasnt times i filled my car up to the top. like it clicked, so i pressed the pump down again and squeezed as much as I can in.
now assuming its not the gas cap as it was fine since, im thinking its under the car. where exactly is it? is it the thing above the rear axle with all the wires going to it?
Old Oct 28, 2009 | 07:52 AM
Coblasts's Avatar
Its one of these two but most likely the purge solenoid under the hood.Its a easy fix to do yourself.
Evaporative Emission (EVAP) Canister Purge Solenoid
On the top of the engine near the oil fill cap
Evaporative Emissions (EVAP) Canister Vent Solenoid
Under the rear of the vehicle, behind the fuel tank attached to the EVAP canister
Old Oct 28, 2009 | 08:10 AM
boostedss26's Avatar
Fuel pump check valve? But if it's that then it's usually hard to start after the car sits for a day or two
Old Oct 28, 2009 | 10:26 AM
StageII07's Avatar
Dude dont worry easy fix had the same problem just my car acted a bit diff..my car would start then i would turn it off and the motor would stay running key off for about 3 seconds then shake and stall. its the EVAP Purge valve celinoid or w.e its called. it sits right on top of ur valve cover its a little box its plastic has wires connected to it. You should also be throwing a check happen to me threw steady check for about a week ran sea foam through it, shell gas got rid of it but came back a few hours later. i also ran system too lean witch i still throw today need to replace MAP and O2 Sensors. but your prob is much simpler advanced auto parts like 30-40 bucks 5 minutes to replace. and it will stop doing that. illl find a pic of it
damn it never mind beat me too it..i was looking for a pic!..lol
Old Oct 28, 2009 | 10:28 AM
Staged07SS's Avatar
Administrator
Administrator
My SS/SC had this happen about a month ago. Everytime I went to fill with gas it would idle, and try to die unless I kept the revs up. It wouldn't act up again until I would fill up. It was the purge solenoid valve. It's part of the EVAP system, and will also give you the check gas cap message. Very simple fix. I replaced it myself.
Old Oct 28, 2009 | 10:35 AM
StageII07's Avatar
what he said i did the same =]..lol
Old Oct 28, 2009 | 10:36 AM
Bad05SS's Avatar
maybe it the nut behind the wheel and the fact the car is yellow
Old Oct 28, 2009 | 12:08 PM
Gestapo007's Avatar
any1 got a engine shot on an LNF of where the purge solenoid is. Its not the little black box on top of the intake manifold with all the vacuum tubes running to it? its gotta be something else your talking about. Pics or ban
Old Oct 28, 2009 | 12:10 PM
X2
Old Oct 28, 2009 | 12:18 PM
Gestapo007's Avatar
ill put my nuts on ur steering wheel if you keep talking like this
Old Oct 28, 2009 | 12:54 PM
SSROMER's Avatar
its the Evap happen to mines i had to smash the gas down to get it started once i replaced the part it was good my friends cobalt is turbo and his went out as well good thing its a cheap fix
Old Oct 29, 2009 | 06:44 AM
Gestapo007's Avatar
bump for an actual pic of this piece on the car
